• Upcoming updates
Suspension spring for S Haller Simonswald 400 day clock
Ajay
Aug 17, 2009
182
India
:)Hi All
Please help me to identify the correct suspension wire for my 400 day clock.Back plate photo is attached and the details are:
1) Height and Width of backplate : 8.5 cm X 4.1 cm
2) Height of the clock : 23.5 cm from the base of the pillar to the top of the crown.
3) Markings : S HALLER SIMONSWALD, No (0) Jewells,Unadjusted,Germany.
Thank you
Ajay
49,686
3,032
I don't find that exact back plate in my book, but all of the thin profile Haller's seem to use a .003" spring. I think you'd be safe starting there. If you have any part of the old spring (looks like you do) and a micrometer, you could measure it for verification.
Ajay
Aug 17, 2009
182
India
Thank you so much for your reply.The wire was in broken condition when I received the clock.Since it was broken from the upper block I fixed it back so there was a 1 cm shortage of length and the clock is running very very fast.the existing wire is little thicker than .0023" size. I am not sure whether the clock was keeping time with the existing wire though the seller said so. Not only that the lower block is attached ( fused ) to the wire ( Not like the usual type with screws on it ).So if I remove the existing wire I have to look for a lower block as the old block cannot be removed.
49,686
3,032
That's interesting. One centimeter is a lot of change, and will cause the clock to run fast. The thinner spring should cause it to run slow.
I'd expect roughly 5 to 6 minutes per hour increase with a short spring, and still feel fairly confident that a .003" is what you need (if the pendulum is original).
Ajay
Aug 17, 2009
182
India
I do no know whether pendulum is original or not.so please have a look at the photo of the pendulum and let me know whether I should use a 0.003 " suspension wire.
Thank you
Ajay
Ajay
Aug 17, 2009
182
India
Hi Ajay,
This clock is the same one you have. It is plate number 1520 in the repair guide.
It runs on an 0.003 suspension and keeps good time.
I think you should be safe enough to try it.
Ivan.
Thank you so much Mr.Ivan.Since you have the same type clock let me clarify few doubts
1) Does it have a plastic base with brass colored coating ?
2) Does it have a plastic dial with brass color and marking ,Seth thomas on dial ?
3) Does it have a plastic hook where you attach the lower block of the suspension wire ?
My clock has all the above qualities ( Bad ! ).:(
Regards
Ajay
ivancooke
Mar 3, 2009
327
Banbridge, Northern Ireland.
Yes Ajay,
My clock has all these features, they probably used plastic to cut down on manufacturing costs.
I think you will find the underside of the base is plastic, but the top is either brass or metal plated with brass.
There should also be a clear plastic suspension guard.
Hope this has been of help.
Ivan.
Ajay
Aug 17, 2009
182
India
Yes Ajay,
Ivan.
Hi Ivan,
Regards
Ajay
49,686
3,032
Looks like Ivan has all of the bases covered :) Hope it works out for you!
Keep us posted!
49,686
3,032
Where can I get a .003" suspension spring for a S. Haller Simonswald 400 day clock?
You'll have to buy a pack, and probably pay minimum order fee, so read the fine print before ordering. Here's a link. #10482
ana1961m
New User
Apr 11, 2011
this is a S. Haller movement plate #1520AAA use .oo3(.076mm) complete unit is 42 or 42A depending on the fork shape. you can order thru timesavers in scottsdale, az. 85267 u.s.a. 480-483-3711 international orders hope this helps
John Hubby
Senior Administrator Emeritus
NAWCC Star Fellow
NAWCC Life Member
Sep 7, 2000
12,295
278
The Woodlands, TX
Ana1961m, welcome to the NAWCC Message Board and to the 400-Day Forum. For your info and for others reading, TimeSavers are OK if you are ordering ONLY the individual springs. If you are looking for a complete suspension unit, TimeSavers does NOT supply Horolovar suspension springs with their units. Unfortunately the results of using these have been poor at best.
Meadows & Passmore supply complete units using Horolovar springs, and they ship internationally. Search for "Anniversary Suspension Unit".
SEL KUMS
New User
Jul 30, 2011
Hi DennyMac,
Please type out 220813583055 on EBAY search box and this will lead you to seller snoopyrb1 who has .003 suspension on sale;)
harold bain
40,832
195
74
Hi DennyMac,
Yes, but for twice the price Timesavers lists them for:rolleyes:
LoisM
Aug 21, 2011
100
Shelton, WA
So glad I found this forum. I have the same clock as being discussed in this thread. Can anyone tell me how long the suspension spring should be once the blocks are attached to a new spring? I really can't afford to buy the Horolovar Repair Guide :(. Besides, Shutterbug mentioned they couldn't find a reference to this particular clock in their guide (assuming it's the Horolovar Guide), so if that is the case, purchasing this guide would be a waste of money.
I purchased this clock brand new in 1975, and 2 yrs. later, my (then) 3 yr. old decided to find out how the clock ticked :eek:. Needless to say, the suspension spring was broken, and the clock has not functioned since. Over the years I have attempted to find a local repair shop with not much success, and just recently learned it was possible to repair it myself :eek:.
If anyone knows how long the suspension spring should be it would help a great deal. And I thank you for any help you can provide. :)
49,686
3,032
Welcome, Emanti! Your suspension should be 124mm from top of top block to bottom of the bottom one. .003" thick.
LoisM
Aug 21, 2011
100
Shelton, WA
Thank you so very much for the quick reply. I'm not good at metrics; however, using an online converter I'm to assume that is equal to 4.88". I can't wait to finally get this clock fixed and running again after all these years. I know it's not worth much; but the fact that it's key wind makes it valuable to me.
Again, thank you.
John Hubby
NAWCC Star Fellow
NAWCC Life Member
Sep 7, 2000
12,295
278
The Woodlands, TX
Imantei, welcome to the NAWCC Message Board and thanks for posting your inquiry. The length you calculated is correct, but when you get the spring be sure to double check how high the pendulum is above the base before you cut it to length. The pendulum needs to clear the bottom of the base cup by about 1/8 inch.
Keep us posted of your progress, you may need some help in getting the beat set correctly after installing the new spring.
LoisM
Aug 21, 2011
100
Shelton, WA
I've taken the back plate off, and have now removed the mainspring barrel. I can't get the cover plate off the mainspring to expose the spring. How do I remove it? I've been tapping on the opposite side of the barrel but it just won't come loose. Am I suppose to tap on the key shaft? I'm using a rubber mallet. The first photo in thread #1 that Ajay uploaded shows a small hole on the cover; mine doesn't have such a hole. There is no room along the edge to even get something between the cover and the outer edge of the drum to even attempt a gentle prying.
harold bain
40,832
195
74
You have to hammer on the wind arbor with your rubber mallet, from behind. It may take some hard raps to get it off. I hold the barrel in my gloved hand, and whack it til the cap comes off.
LoisM
Aug 21, 2011
100
Shelton, WA
Thank you Harold. It worked. I wasn't sure if I should tap on the arbor for fear the spring would come flying out. As you mentioned, holding it in a gloved hand was the ticket. :D And thank you for such a quick response. :thumb:
49,686
3,032
I hold the barrel in my gloved hand and whack it hard on a 2X4.
Reactions: Tony3900
Tony10Clocks
Aug 10, 2010
1,641
62
Northant's
Regards
Ajay
Hello. Just curious, Why would Seth Thomas be on a german 400 day clock
Tony
harold bain
40,832
195
74
Tony, in the latter stages of the history of Seth Thomas, they were reduced to being a sales agent for German made clocks. I have a Seth Thomas cuckoo clock, that is obviously a blackforest product.
Aug 14, 2014
Hi i have same S.Haller Simonswald clock and i need spring for that clock.... Tell me where can i order and is it expensive that? I was at one old clock store and he required me 100euro :mad: wtf .... Please help me
13,664
93
You seem to be missing the suspension spring, top block, bottom block,
fork and screw at the top. The springs by them selves are not that expensive
but it also requires setting the beat once you have the spring.
I'd say the price was high but don't know the European suppliers or what
what it might cost there.
In the US, the parts would cost about $30 and just installing might cost an additional
$50. The price may have included cleaning and oiling. If so, it would not have been
that far out of line.
49,686
3,032
I can't seem to ID the exact plate, but I'm pretty certain that it will require the Horolovar #42 or 42A unit (either one is fine). That will include all of the parts you need. Should be under $30.00 US. Be sure you get a genuine Horolovar, or the timing will be off. Check the supply houses in your country.
LoisM
Aug 21, 2011
100
Shelton, WA
The plate is the 1520AAA, the suspension spring unit is a #42 or #42A. I found the #42A fork to be a better fork which is the one that came with the clock. Also, even though the Horolovar Repair Guide recommends a .003" spring. My clock originally came with a plastic anchor that had cracked. I was able to find a clock with a brass anchor so I replaced the entire movement. I ended up having to use a .028". You could contact Chris Nimon at Horolovar to see if he ships international. You maybe able to get a unit from him, as well as the additional suspension springs. If you plan to repair yourself, recommend getting a few extra packs of replacements springs. They are fragile and if you bend in the wrong place you'll need to replace.
Good luck. My clock has been keeping near perfect time since April 2013.
49,686
3,032
It doesn't really match the 1520AAA, and although it is very close to the 1520AA, it's not a perfect match. However, since the Haller style is consistent throughout, the 42 is a logical choice.
Just-in-time
Nov 28, 2012
533
South Africa
Does anyone know if the suspension bracket on these S.Haller Simonswald clocks are adjustable to set the beat. Most of the suspension brackets I have seen seem to have a have a screw or device that can be tightened or loosened. This one looks like a rivet head and is pretty tight.
Does it just need a little encouragement? If not is this fixed saddle clock. and how does one set the beat?
Burkhard Rasch
Jun 1, 2007
5,220
406
66
Twistringen
yes,it's a snug press fit,moving is sometimes a bit hard.
Burkhard
jdoylend
New User
Dec 30, 2020
I have the same model being discussed in this thread and shown in the photos above by Ivan, and I have a basic question. Is this the same as the so-called “time bomb” Haller clock? Or is this model relatively safe?
thanks,
Jonathan
KurtinSA
Nov 24, 2014
5,846
619
San Antonio, TX
Welcome to the message board, Jonathan! No this is not the "time bomb"...just a regular 400-day clock. I have a few like this...they are not the most robust built clock/movement but can be made to run.
As for setting the beat, you would end up turning the upper mount where the top block of the suspension spring is pinned. This mount is a friction fit to the saddle bracket. The best way to start setting the beat is to check where it currently is set. With the suspension and pendulum hung and not turning, use your fingers to rotate the pendulum one way or the other while watching through the inspection holes for a tooth to drop off the pallet...you should hear a small "tick". Stop turning the pendulum when this happens and carefully remove your fingers and let the pendulum rotate the opposite direction. You should watch the opposite pallet to see when a tooth falls off...making another "tick". The clock is in beat if the pendulum rotates on its own until the second tooth just barely falls off the pallet. If the tooth doesn't fall, or if the tooth falls and the pendulum continues to rotate quite a bit past the "tick", then the clock is not in beat. You would then turn the upper mount to return it to beat. My way of thinking which way to turn the mount is to consider which way the pendulum went too far. Say it was rotating counter clockwise (when looking down), then turn the upper mount clockwise. The upper mount adjustment is very sensitive, so make a change and repeat the swing test and see what kind of progress you're making.
Kurt
Reactions: jdoylend
jdoylend
New User
Dec 30, 2020
Thanks Kurt. That’s a relief.
Regarding setting the beat, I get how to check the beat - that’s how I know mine is a little off. But I am suffering from general ignorance of clock anatomy in terms of identifying the pieces you mention (I have loved all things clock-related since childhood, but am only now reaching a point in life where I can actually own older mechanical clocks so am just starting to learn the innards).
So, is the “suspension spring” the wire on which the pendulum is suspended and which twists back and forth during operation? What is the saddle bracket? Could you point me to a picture?
Thanks,
Jonathan
KurtinSA
Nov 24, 2014
5,846
619
San Antonio, TX
I'll try to use one of the pictures posted above and put some notations on it. Hopefully this helps. Yes, the suspension spring is the very thin wire...it has a sandwich block at the top and one at the bottom that has a pin which hooks to the top of the pendulum. The top block is held in with a screw that goes through the sides of the upper mount and through the top block.
Kurt
Reactions: jdoylend
Burkhard Rasch
Jun 1, 2007
5,220
406
66
Twistringen
sorry to correct, but we should avoid confusion: the bracket is that shaped piece of brass attached to the back plate with two skrews.
this bracket carries the saddle (what You call the "upper mount" in your pic, Kurt) , the cylindrical little brass piece with the slot, in which the top block rides on a fixing skrew or pin.
The saddle is either friction fit or can be fixed with a skrew from the top can be turned to the left or right - and with it the whole suspension unit- in order to set the beat eqal
Reactions: Tony3900
KurtinSA
Nov 24, 2014
5,846
619
San Antonio, TX
Burkhard, you're right...should have checked the guide for some standard terms. But hopefully the poster at least saw what I was pointing to!
Kurt
Antibet
Jan 16, 2023
25
58
Hi there what is the distance between the bottom of the top block and the part that connects to the escape wheel pivots, is it 4mm?
18,235
3,641
18,235
3,641
Drop a 1 mm thick disk/shim into the centering bowl, then get someone to hold the pendulum in place, resting on that disk. A steel ruler should give you the measurement you need (hole to hole).
This will get you close and the 1mm disc is on the shy side. This should make the length very close but most likely a bit long. It's easy to trim by another mm, if necessary.
I used to do this before I got my "book" about 40 years ago ... :) Willie X
Tony3900
Nov 3, 2018
84
58
shutterbug, I have the same clock and have adjusted the pendulum all the way to the minus side the clock is still running really fast, I am using a .003 spring also. any suggestions on how to slow the clock down. could I use a thinner spring? Thank you.
180,023
1,570,385
54,344
o4amopar
911
3,090
