Seth Thomas Suggested pendulum weight range for mantle clock movement # 89 & 4 1/2
Discussion in 'General Clock Discussions' started by John Eckenrode, Apr 11, 2018.
  1. John Eckenrode
    John Eckenrode Registered User
    Mar 3, 2018
    11
    Hello folks, I'm new to this game, and have a couple of seth Thomas movements, one numbered 89c and another numbered 4 1/2. I cleaned and oiled them. I'm noticing that they both run ok using a pendulum weighing 2.8 oz but run for a while and stop on pendulums weighing 4.6 and 5.2 oz. What are your thoughts on the best weight for these movements. Note, one 89c is pictured below.
    Also, a quick question - do the lantern pinions need to be oiled, or just the bushings on the front / back plates?
    Thanks folks!
  2. KyleG
    KyleG Registered User
    Nov 4, 2006
    84
    Most of the S/T clocks I own with 89 type movements came with 5-5.2 oz weights and run fine. Others with more experience may have other opinions.
    John Eckenrode likes this.
  3. Uhralt
    Uhralt Registered User
    3,703
    349
    First of all, don't oil pinions. That would cause excessive wear due to abrasive dirt getting embedded in the oil. Oil the bushings. Your problem might be related to the fact that the clock may be slightly out of beat. A heavier pendulum causes more problems than a lighter one if the clock is out of beat because the heavier pendulum needs to be pushed "up the hill" on one side. The clock is in beat when you hear an even tick-tock.
    It is also possible that you have a power problem and maybe a bushing or more need to be replaced.
  4. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    5,837
    319
    Retired, not tired
    Welcome to the NAWCC Message Board John.
    These are both 89 variants. As such, I believe that they should have deadbeat escapements. Having them in beat is very important as Uhrait notes. I've seen 89's running with the Seth Thomas "Boy on a Fence" Bobs in Sonora Chimes but I'm not certain they were original to the movement. Reportedly that Bob weighs 3.6 ounces and would probably be on the light side for these movements. I don't believe that a 2,8 ounce pendulum is "stock" for these movements.
    Here is a link for setting the beat: https://mb.nawcc.org/wiki/Beat-Setting-101
    When you have a few moments to spare, try to familiarize yourself with the permanent threads at the top of this forum or at the top of any forum. There you'll find a lot of very helpful Forum specific (or general) information at your fingertips.
  5. shutterbug
    40,293
    630
    2.5 to 4 oz should do it. It's not a critical factor in the clock continuing to function. If it stops, it's likely another issue.
  6. John Eckenrode
    Mar 3, 2018
    11
    Thanks folks, all of you! I'm grateful for your help.
    John E
  7. Bruce Alexander
    Feb 22, 2010
    5,837
    319
    Retired, not tired
    You're welcome John. Regarding your question on oiling lantern pinions: Oiling a clock can really open a can of worms around here. With something so basic, you would assume it to all be a cut and dry subject. Believe me when I tell you that it isn't. I think all would (or should in my opinion) agree that you don't want to be squirt-n oil in them things. :)
    Here's a good reference from one of those permanent threads bangster has put together for us. Oil a clock, How To (5 pages) • I know that Uhrait already gave you good advice on the specifics of your question but if you get a few moments, look over bangster's thread on the subject. It may answer questions you haven't asked yet.
    Bruce
