That’s like taking a shower with your shorts on, but it seems to be common practice when the pivot hole isn’t badly worn. These things can put up a fight but will eventually give up. Warm the part and add penetrating oil such as Kroil or liquid wrench and let it work 24 hours, periodically adding more. Have ready tools to pry equally under both sides, the get the part HOT with a small butane torch. Don’t get it red hot but don’t be afraid to get it hot enough for the oil to start smoking. Then pry it off. It should come right off.
An alternate method requires making a brass driver to slip over the shaft. In a brass rod, drill a deep hole that’s a bit larger than the threaded part of the shaft, then drill out part of the hole so it slips over the shaft (make sure the threaded part does not bottom in the hole). Support the plate with a crow’s foot or split stake close to the arbor, heat the part, use the brass driver and small hammer to tap the shaft through the pinion.
Once you remove the star wheel, you will never get it back on in exactly the same place, so youwill need to adjust the collet in the minute hand so it strikes at 12, which is another reason some prefer to leave it alone.
