Stromberg slave question
Calculagraph
Jan 20, 2020
13
New Jersey
I have a Stromberg slave that I am repairing. I have never worked on one before but the movement seems very straightforward. I have a 20V impulse power supply and the coil actuates the rotor when impulsed. There is a secondary rotor (much smaller) that I hope you can see in the pictures. It is on the same shaft as the main rotor and is intended to rotate the main shaft by 1/8th turn so that on the next impulse, the main shaft is in a position that the main rotor can be pulled by the coil.
I can not figure out what causes the smaller rotor to move. I am probably missing a part but would appreciate any help or a picture of a complete system.
Thanks,
Cliff 20211216_163809.jpg second smaller rotor to be actuated.
20211216_163733.jpg 20211216_163747.jpg 20211216_163800.jpg 20211216_163809.jpg 20211216_163733.jpg 20211216_163747.jpg 20211216_163800.jpg
Calculagraph
Jan 20, 2020
13
New Jersey
Thank you! That is exactly what is missing. Do you have any idea where I might get that part or a slave movement I can sacrifice?
I think the slave has some value, it is very attractive. The slave is a 20 Volt Model S7. The clock must weigh at least 20 pounds, I believe solid bronze.
Thanks for your help.
Reactions: S_Owsley
Calculagraph
Jan 20, 2020
13
New Jersey
Thanks, I think I am going to have to wait a while to see if a sacrificial movement shows up on ebay or elsewhere.
175,080
1,531,195
52,559
Otley99
1,063
2,972
