Strikes early
90 Flhs
Dec 26, 2020
Can anyone help please. Working. On this Seth Thomas for a family member. When the moved they lost the pendulum. Found a pendulum and a bob now I have it back together and it strikes at 4 or 5 minutes before the hour. Also where the minute and hour hand are mounted that was bent maybe 10 degrees off. I bent it back and all seems to work but the early strike. Thanks for the help
EE0A32E9-A517-4446-9633-7A6D77E0AEF1.jpeg 3CDC21D9-DC1F-4D01-9118-426D236BB3A5.jpeg
tracerjack
Jun 6, 2016
1,713
249
Lodi, CA
When the movement somehow got dropped on it's nose, I would guess the star arm got shifted a bit. But that's only a guess, so let's wait for others to post who may know other places that could shift the drop of the lifter. This should be posted in the "Clock Repair" section for better answers. Hopefully the moderator will move it.
46,693
1,911
That took a pretty good hit. There's two ways to approach a repair. The hardest is to move the pinion and lifter to the proper position. That would mean a little heat and prying it off with a couple of levers, and then getting it repositioned and tapped back on with a hollow punch. The other might be easier. Try flipping the hand over. Sometimes they are not exact from the factory. In probably 1/2 the cases, that works.
14,049
1,494
The minute hand should have a bushing at the center on that one.
Take the hand off, hold the round center part with a square tool in the center hole a small file tang works well, or you can make a square tool using a nail and a flat file.
With the center part held securely, carefully turn the hand in the desired direction.
Reactions: Jonas
90 Flhs
Dec 26, 2020
Willie that worked thanks a lot. Now next problem it was chiming fine and working great I tryed to set time to see how fast or slow it was and now I can’t get chimes to work. It does have a lever on the side to shut them off but nothing changes in any position I move it to
46,693
1,911
You might have to wiggle the chime drum a bit to free it up. Sometimes they get stuck mid song.
90 Flhs
Dec 26, 2020
It’s amazing what you can find out when you read the paper in the case. I took the movement out to get it running and never read the paper in the case. It plays different chimes and stop chiming at 10:00 then will start again at 7:15. Thanks for all the help appreciate it.
Reactions: Jonas
46,693
1,911
:D
Similar threads
166,139
1,447,306
86,684
ds23pallas
2,883
