Steel or Invar pendulum
Discussion in 'Electric Horology' started by markiemark, Jun 6, 2019.
  1. markiemark
    markiemark Registered User
    Nov 21, 2017
    71
    Is there a way to tell if a pendulum shaft is made of steel or invar?
  2. novicetimekeeper
    Jul 26, 2015
    8,711
    377
    Dorset
    There isn't that much difference in density, 7.85g/cm^3 compared to 8 g/sc^3 for mild steel and both are ferromagnetic
  3. Allan Wolff
    Allan Wolff Moderator
    Mar 17, 2005
    607
    34
    Tulsa, OK
    I purchased a piece of Invar for my last clock build. If it had not come with a certificate, there would have been no way for me to differentiate it from regular steel. It machined like steel, is magnetic, etc. There are probably laboratory tests that can be run, but I am not aware how the typical clock repairer or home machinist would know. If someone knows how, I would love to hear it.
  4. Jim Hartog
    Jim Hartog Registered User
    Jan 6, 2010
    501
    21
    house husband
    Hello,
    Wikipedia says Invar is about 1/3 nickel. Wikipedia does say anything about corrosion resistance, but the Ni content should make it rust free, like stainless steel. Try rusting it in some acid.
    Jim
  5. gloos
    gloos Registered User
    Nov 19, 2002
    10
    Does anyone know if a Synchronome pendulum is made of invar?
    Thanks, Gayle
  6. Snapper
    Snapper Registered User
    Nov 30, 2014
    230
    14
    Lincolnshire, UK
    Synchronome pendulum rods are invar.
  7. steve323
    steve323 Registered User
    Sep 25, 2018
    Does the rate of the clock change when you change temperature?
    Steve
  8. Peter
    Peter Registered User
    Jan 28, 2010
    199
    Bethlehem, Rural NW CT
    What I did:
    Clamped rod at one end on a rigid surface ( used my milling machine table, but any counter top would work), supported it in a couple of v blocks down its length, put a dial indicator on the other end. Heated along the length with a heat gun(hair dryer). I had negligible change in length from room temperature to warmer than I could comfortably hold onto it. Invar!
    -Pete
  9. Peter
    Jan 28, 2010
    199
    Kevin W. likes this.
  10. rogerj
    rogerj Registered User
    Dec 21, 2014
    128
    retired broadcast engineer
    Cornwall
    I once bought a much neglected Mk2 Synchronome that had plenty of surface rust on the rod....
  11. Snapper
    Nov 30, 2014
    230
    14
    Lincolnshire, UK
    Agreed. I was fortunate that my Synchronome was in superb condition when I acquired it as it had been in a church rather than a factory. Even so there was surface rust on the pendulum rod.
