Hello, I know little about this clock or any other; but, years ago I inherited a few slave clocks. I've been running one with a battery operated pulse generator for a long while. I've acquired a Standard Electric SYN-AR2 Master clock and it is in need of parts. Specifically the motor that drives it. See the picture of where it should be. It was not there when I acquired the clock. There may be other things missing; but, the motor was easy to figure out. Are motors that would work in this clock available anywhere? Anyone know if something can be retrofitted to it? Eventually, I will try to run a slave clock or two from this; but, first things first. Thank You
If someone doesn't have the exact clock, you may have to do some figuring out. You'll need to figure the gear ratio used from the output to what is used to generate the pulses. This form of motor is common but they come with all kinds if different rotation rates at the output shaft. Dwight
