Standard Electric standard electric master
Discussion in 'Electric Horology' started by wingardclocks, Apr 10, 2014.
  1. wingardclocks
    wingardclocks Registered User
    Oct 1, 2007
    321
    I need a few answers about this clock, picture of a clock which is not mine below. The one I have isn't complete.
    1) What size chain is used to wind the weight?
    2) What is the size & number of teeth on the chain sprocket in the movement?
    3) I have the switch that shuts off the motor when the weight is wound. What activates the winding motor to wind the weight?
    Thanks in advance
  2. eskmill
    eskmill Registered User
    NAWCC Fellow NAWCC Member
    Aug 24, 2000
    7,135
    31
    My recollection is #35 roller chain was used and the width of the usual "eyebrow" style case is an inch wider than the magnet wind clocks.
  3. paradise
    paradise Registered User
    Jun 24, 2007
    92
    retired
    florida
    This clock uses a ladder chain and it is quite available. It is in inches not mm. I had one several years ago but don't remember the sizes. Mine went to Dr. Blore in Los Angeles area. His contact info should be available from electric horology chapter. While I cant speak for him I did find him to be very helpful when I contacted him once several years ago with a problem. Perhaps an email ti him might help.
