From a prior post, I was deciding upon a diode to mitigate arcing on the contacts. I ended up using a Schottky 1N5817, rated at 1A and 20V. My clock seems to run fine on a 12V source, and draws about 0.5A during contact. No more arcing.
Now, onto the power reserve of the clock's spring. Fully wound, the clock will run about 50 minutes or so, which is apparently correctly. If I let the clock run down (as I do to measure the power reserve), and then wind it manually for approximately 10 min of power reserve. And then apply electrical power to allow it to run normally. After several days of operation, the power reserve is max'ed out again (around 50 minutes).
I've checked the 'kicker' that winds the main spring. It is advancing one tooth every minute.
I'm curious as if this is normal operation, or do other's Standard Electric clock's power reserve remain somewhere between completely wound and completely unwound?
I would think that the clock was designed so that the power reserve would stay about 50%, but maybe there is a bias in the design to slightly wind the clock over time, with the thought that a clock fully wound is better than one that gravitates to an unwound (and stopped) state.
Just wondering out loud, as this is my first Standard Electric.
Thurmond
PS Coming from the watch world (when the eyes were young), I use the term 'power reserve'. I don't know if this is the correct terminology in the clock world or not.
Thurmond
