Staking set cleanup
107WestStreet
Just cleaned up a K&D staking set. Had to buff off some rust and debrey. Will the newly cleaned areas rust after buffing with steel wool. I would hate to add any oil that could infect parts, but what do you reccommend.
Roger Huegel
Aug 24, 2000
117
I just cleaned up two staking sets myself and then I sprayed them with WD40 and wiped off the excess with a cloth.
Andy Dervan
Gibbs Literary Award
NAWCC Star Fellow
Oct 23, 2002
2,833
109
Hello,
Typically coating items with a light film of oil after use is the traditional method to keep tools from rusting. Remember fingerprints actually leave a residue that is corrosive to metal.
WD-40 is a cleaner rather than a lubricant and is designed to eliminate water.
Andy Dervan
Roger Huegel
Aug 24, 2000
117
Andy
Reading from the back of the WD-40 can (condensed):
Lubricates
Moving parts...
Cleans
Most surfaces...
Protects
Against rust and corrosion...
Penetrates
To free stuck parts...
Displaces Moisture.
To restore wet parts...
One of the things that I enjoy doing is restoring old machinery and tools. WD-40 is great for cleaning and coating metal to protect it from rusting.
I've always said that you can fix most everything with a hammer, duct tape and WD-40 :)
burnz
Inactive User
Jan 24, 2006
1,706
WD-40 does all those things primarily due to its water displacing properties. If it can displace moisture than it can help keep away rust. It also contains "some" lubricating properties.
WD-40 stands for=== water displacement-trial number 40. That's how it got it's name. On the 40th. trial--they were satisfied with their product---hence the name---WD-40.
bobswatch
Sep 3, 2004
253
Hi Burnz:
Am I correct in saying that NASA wanted a product made to displace moisture on space ship parts ? As you state the water displacement 40th try ended the development process and the product made its way to the commercial market after they no longer used it.
Just my two cents on the subject.
Bob
burnz
Inactive User
Jan 24, 2006
1,706
Don't know for sure about NASA etc. I do know that I read (can't remember where) along time ago the way that WD-40 arrived at it's name.
I actually was thinking it was a private venture.
burnz
Inactive User
Jan 24, 2006
1,706
True--but we are not speaking of WD-40 on clock movements here. Only tools,equipment,machinery etc.
Timm
Nov 19, 2005
379
I'm not absolutely sure, but I think I saw on the History Channel that WD-40 was developed near the end of WWII.
doc_fields
Sep 29, 2004
1,318
32
Greentop, MO
precisionclockandwatch.blogspot.com
WD-40 also makes a great fireball when thrown in the burn barrel. :biggrin: Everytime some idiot sprays their cuckoo clock with it, I'd like to take it from them and toss it there.
Reactions: Slowmojoe
BobC
Jan 3, 2006
77
The displace moisture concept is exactly correct. I had an old Dodge (many decades ago) that every time it rained it wouldn't start. If I'd pop the distributer cap and give it a quick squirt of WD-40, pop the cap back on it would start every time. WD-40 has also been used as a replacement for Ether to fire up an engine that would kick in cold weather. Non of this of course has anything to do with clocks or clock tools, just personal uses in years gone by.
Bill_NY
May 23, 2005
325
David-
It is called Cratex here. At least I believe that it is probably the same as your Garyflex.
Bill
SSWood
Sep 27, 2004
19
David, I had the same problem with rust,in my workshop .. well heavy condensation when the weather turned chilly, not the famous North Sea mist. Solved it by 'borrowing' the heater from my greenhouse .. has much lower thermostatic settings than a domestic one, .. right down to frost free .. so it was pretty economical to keep the temperature just above the dew point. Worth all of the few pounds ( under £20.00 I think ) from B&Q. May be worth a try.
Steve
technitype
Feb 19, 2012
625
10
I use small foam strips called "rust blockers". These are self-stick strips that I place inside my staking tool box.
They are very effective at preventing rust.
The brand name is "Bullfrog".
technitype
Feb 19, 2012
625
10
Andy Dervan;15608 said:
Hello,
Andy Dervan
WD-40 is no good for long-term prevention of rust, since it eventually evaporates off.
Kevin W.
23,047
514
A better product that we use in the machine shop on metal surfaces is T9, Boeshield.
WD 40 is a very poor rust inhibitor.
Developed by Boeing.
technitype
Feb 19, 2012
625
10
Heck- getting oil on the watch parts would be the LEAST of my worries...getting oil off watch parts is EASY; getting rust off of watch parts is a B#TCH!!!
skippp66
Aug 29, 2010
72
Confucious say:
If is moves.....duct tape it; if it doesn't move...WD40 it!
Skip, that Hamilton Nut
Firegriff
Feb 22, 2013
757
I use a product from Berchwood Casey called "Barricade" it is made for rust prevention on long storage of Guns also works well on any tool comes in spray or drip can.
technitype
Feb 19, 2012
625
10
Firegriff;955586 said:
WD-40 was good at keeping Nuclear warheads aluminum outer shell shinny.
...except, we are not talking about "keeping nuclear warheads shiney"- we are talking about preventing RUST on a staking tool set.:whistle:
LarFure
Nov 30, 2003
938
www.lfure.us
The formula for WD-40 has been changed so it doesn't burn. I used to use it for starting diesel engines in cold weather, but now when you spray it in a engine it's like dumping water in the cylinders.
As far as protecting any watchmakers tools from rust, I found that soaking a rag with any light oil and using that to wipe off the tools will keep them from rusting. I do this to my staking set and lathe collets every other year. I've never had any trouble with rust since I started doing this.
BigAl
Aug 24, 2011
213
Pembrokeshire
How about keeping the staking set in a plastic storage box and include a few packets of of silica gel?
BigAl
technitype
Feb 19, 2012
625
10
You need to remember that staking sets are housed in wooden cases- and wood absorbs and holds moisture...
I have been using "Bullfrog rust-blockers" for several years, and I have not had any trouble with rust
BigAl
BigAl
Aug 24, 2011
213
Pembrokeshire
Each to their own technitype. If it works for you that is great.
Packets of silica gel come in a huge variety of sizes so it is easy to select one, or several, that will fit around whatever you want to protect while it is in its box, no matter what the box is made of. I suggested a plastic box merely as a suggestion. Any container with a lid is satisfactory.
If they get too damp the packets do not need much heat to dry them out ready for re-use. On top of a central heating radiator for a couple of hours is fine.
BigAl
Lassen Forge
New Member
May 15, 2016
I have a K&D set I just picked up and about 1/3 of the stakes are rusty - I decided to try Simichrome polish and a soft rag... while I do NOT recommend it for the longevity of the rags, with sufficient elbow grease they are once again smooth, shiny, and non-rusty. Of course the holes take some careful work with wood and a pic, but so far no blems.
164,686
1,432,667
85,738
cspeed8
2,863
