ST 89c keeps pausing at same spot
Discussion in 'Clock Repair' started by JayRs, May 5, 2014.
  1. JayRs
    JayRs Registered User
    Mar 17, 2014
    25
    Vermont, USA
    This is my first serious clock repair. The clock is ST Adamantine with an 89c movement that had a broken mainspring. The clock was disassembled, cleaned and inspected. All pivots and bushings looked good so I put in a new mainspring and carefully reassembled the the clock.
    Everything seems to working fine except the escape wheel keep stopping in the same spot on each rotation. Sometimes it works it way past and sometimes the pendulum just runs down while trying to get pass the spot. I've marked the spot on the escape wheel and it is only at that tooth where there is a problem. The video below show what is happening. I don't want to start "adjusting" the wrong things so I'm hoping for some advice to point me the right direction.
    [video=youtube_share;v6igGaEw570]http://youtu.be/v6igGaEw570[/video]
  2. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    142
    deceased
    Looks like that tooth is just slightly bent. Pretty easy repair. You will need a small pair of smooth jawed pliers to straighten it up by a thou or two.
  3. JayRs
    Mar 17, 2014
    25
    Vermont, USA
    Thanks Harold, to the right or left (I'm pretty new to this)
  4. harold bain
    40,850
    142
    deceased
    This is where you have to do some thinking. Watch the action of the escapement and picture which direction of bend would allow the pallet to fall properly instead of hitting the tooth. Keep in mind it has to fall on the same side it does on every other tooth.
  5. JayRs
    Mar 17, 2014
    25
    Vermont, USA
    Ok, since it seems to be hitting the tip of the tooth when it should be sliding down the backside of the tooth, I say to the left.
  6. harold bain
    40,850
    142
    deceased
    Correct. It only needs a very small adjustment so try not to go too far with it.
  7. JayRs
    Mar 17, 2014
    25
    Vermont, USA
    That and a few strokes with a flat file seem to do the trick. Ticking along nicely. The 89 movement seems to be pretty forgiving for a newbee. Time to oil her up, finish cleaning up the case and I'll my first clock done thanks to all the resources and help on this board.
  8. harold bain
    40,850
    142
    deceased
    Good work, Jay. If the action is smooth and consistent through 360 degrees rotation, you've got it.
  9. Dave T
    Dave T Registered User
    Dec 8, 2011
    2,646
    69
    retired accountant
    NC
    I'm impressed! Took me about 4 times to watch the video, before I could see it, even after you told me what was wrong.
    This is good stuff for newbies, (like me).
  10. Douglas Ballard
    Douglas Ballard Registered User
    Dec 2, 2011
    1,520
    10
    Network Information Management/Computer Repair
    Alma, MI
    If you think this is fun, wait until you get an EW with more than one wayward tooth! Nice work on fixing your problem.
