Help Squeaky Cuckoo Movement
Watchdog21
Jul 24, 2020
13
58
Tampabay Florida
I have read a few threads about squeaking sounds but I’m still not sure of the source yet. I recently cleaned the movement even though it looked decent to begin with. I oiled it and it still squeaks so then I stated putting a drop of oil in places I suspected and just planed on cleaning it again one I knew the source of the squeak.
Still squeaking. I have captured a 20 sec/ video of the movement ticking and squeaking. At first, I figured this was an easy find and fix but now I am at a loss of ideas.
Any advice is appreciated.
44,311
1,352
I can see that your crutch loop gap is too wide. It also might be off center. The pendulum hanger needs to be centered in the loop, and just enough space to allow the up and down movement to be unhampered as it swings. A tiny bit of oil there is acceptable, and might stop the squeak.
Watchdog21
Jul 24, 2020
13
58
Tampabay Florida
Will give it a look and try this weekend. Thank you.
tipsy
Nov 19, 2016
10
have you tried removing the pendulum for a moment? Does it still squeak then?
tom427cid
Mar 23, 2009
1,663
100
Moultonborough,NH
Sometimes using the grease used on chime levers works better----lasts longer
tom
Peter John
Sep 4, 2018
314
153
Scottsdale, Arizona
I think that “squeak “ is coming from the verge. A drop or two of pivot oil on the verge faces should silence it. It’s a high pitched squeal between the brass tooth and the hardened steel faces of the verge. Peter
Reactions: roughbarked
Watchdog21
Jul 24, 2020
13
58
Tampabay Florida
I discovered something as I was messing with it. I had removed the weights and was getting ready to put them back on when I noticed that the squeaking did not start until I put the weight on the time side. Strike side was fine.
kinsler33
Aug 17, 2014
3,488
429
73
Lancaster, Ohio, USA
Here's a cheery note: A search through the archives of this scholarly forum will reveal that squeaky cuckoo clocks are not easy to remedy. That's probably because there are so many things that can squeak given the Old World craftsmanship that goes into these wretched things. The crudely-stamped pendulum hook can be squeaking on its hanger, or perhaps it's loose on the two crummy nails that sort of hold it to the wood pendulum rod. Same for the pendulum bob. Look at the hook that holds the pendulum rod on its little trapeze, and the loops of the trapeze itself. When you oiled the clock you'd have oiled verge pivots and escape wheel teeth, so it's probably not those. So start oiling or perhaps applying a tiny smear of grease to anything that's supposed to move or perhaps not move.
Sometimes the squeak disappears spontaneously, too, thus foiling orderly scientific squeakicide.
Mark Kinsler
Reactions: Altashot
Watchdog21
Jul 24, 2020
13
58
Tampabay Florida
So it still squeaks after oiling the verge faces?
I'd be taking the verge out and looking at the pivots.
but you can try a little oil on them first, to see if it stops the squeak.
Correct. If anything, I have now progressively over oiled it one spot at a time but now luck yet. It looks like I will just take it apart, put the movement on a stand and let it run to maybe locate the source.
Watchdog21
Jul 24, 2020
13
58
Tampabay Florida
Mark Kinsler
It certainly is being tricky. Even though I oil the verge pivots, I did not put oil on the escape wheel teeth. I believe that it is time to take the movement out and put it on a stand to try and track it down.
44,311
1,352
If you put a little oil on the entry pallet, it will migrate to the EW teeth with about the right amount of oil. EW teeth normally get just a little oil.
D.th.munroe
Feb 15, 2018
670
234
BC Canada
I would try a little smear of oil on the sides of the pendulum rod that touch inside the crutch loop.
Topic related ad experiment
160,866
1,395,696
82,875
jr webster
1,099
2,787
