Spindle Issues - Have I Messed Up Again??
I stripped a Cuckoo Clock Mechanism recently and was left with the Birdstock and the Spindle still attached to the back plate. See picture 1. I had partially removed the Spindle, before being advised by a Member, that it was not really necessary.
So then, having cleaned everything, I want now to reassemble. The first thing, obviously, is to reposition the Spindle back to where it was. Problem is - where exactly was it?? I used a couple of sections of thin tube, to support the Gear side and the other over the Spindle, to tap down onto the brass Bush.
The inevitable happened! One tap was too little and the whole Spindle was still very loose. Two taps was the same, three taps and it was still slack. Four taps, (you guessed it) now more or less solid. It took a further 15 minutes with various impliments to get the Spindle moving again. The evidence is there, in the form of scratchs on the plate and a circular score mark. Picture 2 and 3.
My questions are thus. What is the best way to manipulate this component in future? How do we know exactly what clearance is required? If I can now turn the Spindle by hand with no great friction will it be OK? Should I put a dot of clock Oil at the junction?
Please advise. Thank you, Howard
