I've restored two Sessions banjo clocks for friends by purchasing various bitsas from Ebay. I have left over a motor. I've gone through it and the motor now runs perfectly. I've put shrink-wrap tubing over the original cloth covered wire. Anyone want/need this motor? Contact me by private message for details if you do.
Note that the gear-train has a chewed-up fiber gear that needs replacing before it will drive the hands.
The motor is the type that mounts to the plate with two screws instead of using a spring-washer. However, since the plates for both a screw-on motor and a spring-washer motor are otherwise identical, you can use the supplied plate with your mechanism and have a running clock.
