Spare Schatz 53 46/06 First Wheel
Discussion in '400-Day & Atmos' started by AshleyVaz, Sep 5, 2018.
  1. AshleyVaz
    AshleyVaz Registered User
    Mar 15, 2016
    12
    Does anybody have a spare Schatz Miniature 53 46/04 First Wheel? Would be happy to pay for it. I've looked on ebay but no luck.
  2. Burkhard Rasch
    Jun 1, 2007
    4,803
    149
    General-and trauma surgeon
    Twistringen
    I have several butchered-up small Schatz mvmts,please post a pic of Yours,I´m pretty sure I can help.
    Burkhard
  3. AshleyVaz
    Mar 15, 2016
    12
    Please see attached pic of the 1st wheel also on the Terwilliger's Guide this is listed as First Wheel 46/04
  4. AshleyVaz
    Mar 15, 2016
    12
    Please see below pic it is listed on Terwilliger's guide as First Wheel 46/04 for Schatz miniature.
  5. Burkhard Rasch
    Jun 1, 2007
    4,803
    149
    Twistringen
    Thanks.Please post a pic of the back plate so that I can see which mvmt. it is!TIA
    Burkhard
  6. Burkhard Rasch
    Jun 1, 2007
    4,803
    149
    Twistringen
    ....need to see the backplate to chose the movement from which to pick the wheel.
    Burkhard
  7. victor miranda
    victor miranda Registered User
    Jan 13, 2017
    366
    42
    computer programming stuff
    Baltimore
    as far as what causes a schatz 53 to be set in the 'parts' bin in the order
    I have found... failed suspension spring followed by either a bent center arbor or two teeth stripped off the
    wheel you hunt.
    .... I have un-bent a center arbor....
    I have seen at least one person's video for replacing teeth.
    best bet is buy a low priced thing off the bay.
    I can't find homes for the clocks I have repaired.
    victor
  8. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    3,657
    142
    Aerospace Engineer (Ret.)
    San Antonio, TX
    What's the diameter of the wheel? Number of teeth on the wheel and number of leaves on the pinion? What's the length from the end of the pivots? How "tall" are the pinion leaves...how long are they?
    Kurt
  9. Burkhard Rasch
    Jun 1, 2007
    4,803
    149
    Twistringen
    if You have the model depicted below,You can PM me and get the first wheel for free.
    Best regards
    Burkhard
  10. AshleyVaz
    Mar 15, 2016
    12
    Thank very much Burkhard, see attached seems to be the same.
    Ashley
  11. AshleyVaz
    Mar 15, 2016
    12
    Hi Kurt,
    The outer of the wheel diameter is 2.1cm, 4 leaves on the pinion and length from the ends of the pivots is 2.5cm. The leaves of the pinion are 0.3cm long. The number of teeth are 68.\
    Ashley
  12. AshleyVaz
    Mar 15, 2016
    12
    Hi Victor,
    Yes seems that one of the teeth on the first wheel is chipped away causing the clock to stop every 12 hrs.
    Ashley
