source for non-cheap brass tension washers?
bruce linde
ADMIN / MODERATOR
8,659
1,306
oakland, ca.
clockhappy.com
i have some of those inexpensive brass tension washers (with squared ends) from timesavers... i don't like them very much.
does anyone have a source for better quality ones? perhaps steel, with small holes that can be broached to fit minute hand arbor shoulders?
yes, i know i can (try to) make such out of old mainsprings... and will try again... maybe i've learned enough to be more successful this time out. :)
14,068
1,500
I bought such a set long ago but I'm not sure they are still available. They were blue steel, made for old French and German clocks. They came in a small plastic box with numbered compartments. The set was a bit pricey but you could order refills!
Will send a photo, if you like. Willie X
bruce linde
ADMIN / MODERATOR
8,659
1,306
oakland, ca.
clockhappy.com
willie - that's exactly what i'm looking for ... a photo would be great. i will also reach out to labounty and see if anyone else has anything to offer. much appreciated. b
14,068
1,500
bruce,
Hope this helps. The round center holes are undersize and have to be enlarged with a diamond cylinder shaped burr. Each tray was once numbered on a card that peeled off the bottom an is lost.
The reason for the 'TOP' marking is because of what happens when you open the box upside down !!!
MuseChaser
Feb 5, 2019
456
122
...The reason for the 'TOP' marking is because of what happens when you open the box upside down !!!
Even though it was right-side-up, I lifted one of those small compartmented boxed assortments of bushings without holding onto the bottom at the same time. The top held the bottom just long enough to get it high enough so that when they did surprisingly separate, the bushings became..... ummmm.... integrated fully ..... all over my workbench. Still haven't re-organized them, and have instead adopted the Biblical method of bushing selection. "Seek and ye shall find"....
14,068
1,500
MC,
There is an old saw amongst clock people where "spilling your bushings" actually means loosing some of your mental capabilities ...
Anyway, I do the same as you. Never trusting what it says on the drawer. :)
Reactions: MuseChaser
D.th.munroe
Feb 15, 2018
924
309
39
BC Canada
Just did that with a huge assortment of taper pins.
166,191
1,447,873
86,723
CrisWinston
2,882
