Source for dial pan nails.
Discussion in 'Clock Repair' started by doc_fields, May 27, 2020.
  1. doc_fields
    doc_fields Registered User
    Sep 29, 2004
    1,297
    26
    Clockmaker/Watchmaker
    Greentop, MO
    #1 doc_fields, May 27, 2020
    Years ago when first starting out in this business, I bought a small package of these nails that are used on a lot of Tambour clock cases to hold the dial pan to the case from Timesavers. I've used up all these nails now, and thought I'd order more from them. I've ordered the #18 and #16 sizes, all of which they had in bulk packs, but both of these sizes seemed like roofing nails compared to what they used to have, just way too big.
    The nail I'm looking for is just shy of 1/2", with a rounded head and a .032 diameter shank, brass plated, and with a sharp tip at the end. Can you help direct me to someone that may still have these? Thanks!....................gary
    Post Script; Come to think of it, they're just about like the nails to hold the cuckoo dials to the case also. Checked that in Timesavers under the cuckoo dials, but to no avail.
  2. POWERSTROKE
    POWERSTROKE Registered User
    Jan 11, 2011
    909
    64
    21069 or 10540 at timesavers?
  3. doc_fields
    Sep 29, 2004
    1,297
    26
    Greentop, MO
    The 10540 does not have a round head, and they're #18 size, which to me is way too big, and the 21069 is an assortment, which when you look at it closely, does not match my description and they are too long, I need 1/2" Thanks!...........................gary
  4. chimeclockfan
    chimeclockfan Registered User
    Dec 21, 2006
    4,027
    211
    Chime clock & gong studies.
    WI
    I just use round headed tacks or brass nails from the hardware store. Works well, no problems. Don't recall the exact size but they weren't anything obscure.
  5. D.th.munroe
    D.th.munroe Registered User
    Feb 15, 2018
    462
    163
    Full time clock and watchmaker
    BC Canada
    I thought you could get escutcheon pins that thin, I have some but the smallest I've been able to find online were 1/4" 3/8" and 1/2" but 18 gauge so .05?
  6. bangster
    bangster Moderator
    19,695
    406
    Check out Micro-Mark and Amazon. Google "tiny nails".
    doc_fields likes this.
  7. doc_fields
    Sep 29, 2004
    1,297
    26
    Greentop, MO
    As usual Bangster, you "hit the nail on the head" (pun intended!). I found what I wanted at MicroMark. Here's the link for others to find:
    Mini Nails, 3/8 Inch Long x .020 Inch Dia. (Pkg. of 100)
    I checked out Black Forest Imports also, they had them, but I'm not paying $29.60 for 50 of them, or $9.60 for 10. That's crazy! I'm paying $5.95 for 100 of them, more reasonable!
    Thanks again Bangster!............................gary
  8. shutterbug
    43,153
    1,179
    Local hardware, usually called Brad nails.
  9. POWERSTROKE
    Jan 11, 2011
    909
    64
    What would you use to hold cuckoo dials on and also cuckoo trim?
  10. doc_fields
    Sep 29, 2004
    1,297
    26
    Greentop, MO
    I would use the nails I'm looking for, because the dial on cuckoo clocks uses almost universally the same as MicroMarks'. I have other nails if needed for trim and such..........................gary
  11. POWERSTROKE
    Jan 11, 2011
    909
    64
    Good to know. I have two clocks here (cuckoo) that need the surrounding trim re-installed. Does anyone know the size I would need? No existing nails....
  12. doc_fields
    Sep 29, 2004
    1,297
    26
    Greentop, MO
    How thick is the trim? Are the old holes still visible?
  13. POWERSTROKE
    Jan 11, 2011
    909
    64
    The holes iirc are still there. I’m not at home now. I would say 3/8”
  14. chimeclockfan
    Dec 21, 2006
    4,027
    211
    WI
    Be careful that the new nails are not any larger than the old ones, else it may try to warp and split the case. As noted above, any decent hardware store should have a variety of nails which include something which will work.
  15. bangster
    bangster Moderator
    19,695
    406
    In my part of the world, hardware stores don't carry tiny nails. Hobby shops, maybe.
