Electric WW Source for #3510 Miyota Chrono. Quartz Movement
Discussion in 'Watch Repair' started by fijidad, Oct 22, 2019.
  1. fijidad
    fijidad Registered User
    Feb 28, 2010
    250
    25
    Escondido, CA
    I have this watch in for repair; does not function at all with fresh battery(s) and Esslinger does not carry a replacement. Does anyone know of a source for this movement...or a suitable replacement? Thanks, Dan
  2. Skutt50
    Skutt50 Registered User
    Mar 14, 2008
    3,361
    82
    Gothenburg
    I normally avoid quartz movements but I had a Casio Wave Ceptor on the workbench the other week. New battery but still dead!
    Tuns out I had to shorten two points (with a pair of tweezers) to get it moving. Works like a charm afterwards.
    Do you have access to a service manual for the movement? Perhaps there is a simple way to get it moving again!
  3. Rick Hufnagel
    Rick Hufnagel Just Rick!
    NAWCC Member Donor Sponsor
    Oct 25, 2018
    1,003
    1,194
    Plumber
    Pittsburgh pa
    The Seiko alarm Chrono I had was the same way. Had to reset it the same way skutt mentioned.
    It's worth looking into, before changing the movement. I thought mine was a goner, and it wasn't.
  4. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    3,269
    162
    watchmaker
    Western NSW, Australia
    Such watches that require shorting usually have a designated AC position pointed out with an arrow. This merely resets the computer. As far as I can tell, Miyota no longer produce this movement.
    you may attempt to measure everything and seek for any other movement which may be interchanged.
    There are also other reasons why a quartz watch will not go with a battery. Why not take the few minutes to test all of these first?
  5. roughbarked
    Dec 2, 2016
    3,269
    162
    watchmaker
  6. fijidad
    Feb 28, 2010
    250
    25
    Escondido, CA
    Thanks guys for the tips...I'll see if I can find the manual and hopefully can resurrect it using the shorting method. Best, Dan
  7. fijidad
    Feb 28, 2010
    250
    25
    Escondido, CA
    I was able to find the manual online for this Miyota 3510 quartz movement, find the correct battery type (399) vs. the 395 that was in it, and discover that there is a procedure that I did not follow in trying to set this in motion the first time. So a big THANK YOU to the advice provided here and I'll let you know how this comes out. Best, Dan
  8. fijidad
    Feb 28, 2010
    250
    25
    Escondido, CA
    Skutt50 provided me some additional information which confirmed that the correct cell battery for this movement is a 395, but the procedure one needs to follow to get it running, I had no knowledge of. I'll proceed and see what happens. Grateful thanks to Scutt50.
  9. fijidad
    Feb 28, 2010
    250
    25
    Escondido, CA
    I was able to perform some electrical tests with a known good button battery, and found the two first tests to be bad.
    I removed the movement and found water had entered through two of the adjustment buttons, and I'll assume that's what killed this movement.
    So, I'm back to wondering if there is a replacement/substitute for this Miyota #3510 movement?
  10. Skutt50
    Mar 14, 2008
    3,361
    82
    Gothenburg
    Sorry to hear that........
    Good luck with the search.....
  11. roughbarked
    Dec 2, 2016
    3,269
    162
    watchmaker
    Try this. I know it is two months ago but he had three. http://calibercorner.com/miyota-caliber-3s10-3510/ read to the last but one post.
  12. fijidad
    Feb 28, 2010
    250
    25
    Escondido, CA
