Some Questions on a Waltham Grade 636
Discussion in 'Watch Repair' started by ANDY YALE, Apr 1, 2017.
  1. ANDY YALE
    ANDY YALE Registered User
    Jun 14, 2013
    465
    This is a model 1908 that has some features that are new to me. First motor barrel I have worked on, but it was easy to figure out once I recognized what it was.
    However, I'm curious about this screw on the underside of the train bridge which apparently holds the escape wheel upper jewel setting in place. Not seen one before.
    Also would like to know if these two pieces are assembled together and put into the watch as a unit. The came out that way. The bottom piece that holds the castle gear and it's shaft is a mighty tight fit into the plate. I'm one step ahead of myself but forearmed is forewarned. [​IMG][​IMG]
  2. Mark UK
    Mark UK Registered User
    Apr 13, 2015
    268
    Andy, I am going through a learning curve right now with the 1908 as well having just serviced half-dozen grade 635 and up. For the winding shaft (second pic) I have found that it is easier to assemble/lube as a complete unit then pop it onto the main dial plate. I then put the barrel bridge temporarily in place to hold the shaft in position so I can turn the movement over and screw on the small disc that covers the idler gear and holds the shaft in position.
    As for the escape wheel jewel, is it a capped jewel setting? I would be be surprised to find one of those as well, especially on a 17J.
  3. Dave Coatsworth
    Dave Coatsworth Super Moderator
    Feb 11, 2005
    3,896
    That should be a capped jewel. When you remove the retainer, both the hole and cap jewel will come out in that direction.
  4. ANDY YALE
    Jun 14, 2013
    465
    Yes, the jewel setting is different than the others - it has a high profile setting. Thanks, guys.
  5. ANDY YALE
    Jun 14, 2013
    465
    Actually, that jewel is not capped. It's a single jewel, a hole jewel with a raised jewel setting. I guess it's screwed in from the bottom because the setting is too high to allow for screws on the top side.
Similar Threads - Questions Waltham Grade Forum Date
Waltham 1883 question Watch Repair Oct 26, 2016
Waltham dial question Watch Repair Oct 22, 2016
Waltham hairspring question Watch Repair Sep 7, 2016
Waltham 1908 balance staff question Watch Repair Aug 27, 2016
Waltham dial question Watch Repair Apr 3, 2016
