Over in the European section I've a thread where I'm documenting my 1883 Longines Pocket Watch restoration that I've just started.
I've started the tear down and have encountered some problems:
The first issue is that I'm not sure there is any power into the watch as the watch cannot be wound nor set, so I'm not sure the mainspring is de energized.
To wind it down I would put the winding stem on, slightly wind it to take the force off the click, then pull the click back and let it slowly wind down controlling the rate with the winding stem.
Unfortunately I cannot advance the winding - I've put a bit of torque on the winding stem and it won't budge enough to pull back the click.
Thoughts on how to figure out if the mainspring is energized? The escape wheel nor any of the gears move then you push the pallet wheel back and forth.
The second issue that you can see in the image is the broken screw head - only half is there - any ideas on how to get this out? Do I loosen the bridge plate and try to (very gently) break off the remaining portion of the screw head and then back out what's left with pair of micro needle nose serrated pliers?
Thanks -
John
Thanks -
John
