Soluvar and dial signature
Discussion in 'Reverse Glass and Dial Painting' started by Bruce Barnes, Dec 31, 2011.
  1. Bruce Barnes
    Bruce Barnes Registered User
    Mar 20, 2004
    1,863
    19
    I have an original dial that is in pretty good shape but because of age and light exposure the signature has faded.
    Will an application of Soluvar "freeze" the fading in its present state and stop further deterioration?
    Thanks,
    Bruce
  2. Thyme
    Thyme Banned
    Sep 18, 2006
    3,948
    metro NY area
    Is the dial painted? Silvered? Paper?
    A photo would help. :)
    As far as I know Soluvar is not UV resistant.
  3. Bruce Barnes
    Mar 20, 2004
    1,863
    19
    The dial is painted and if Soluvar is not UV resistant then the sunlight etc would continue the process . This fading is probably a combination of both.
    Until the clock arrives this is the only photo and not real good,but you can see the faint J C Brown signature.
    Bruce
  4. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    142
    deceased
    Bruce, if the signature isn't flaking off (doesn't appear to be), it likely won't deteriorate further unless the dial is cleaned, which is likely why it's faded. Adding varnish would probably make restoration harder, should you decide to send it out at some time.
  5. Jeremy Woodoff
    Jeremy Woodoff Registered User
    Jun 30, 2002
    4,075
    40
    Brooklyn
    Keeping it out of direct sun and fluorescent light is probably a good idea.
  6. Bruce Barnes
    Mar 20, 2004
    1,863
    19
    Thanks to all.....the clock arrived and the works are dirty but in original condition.The dial says J C Brown,Bristol Cn,US.
    The works are marked Brewster and Ingrahams and are ribbed.No count lever,so must be rack and snail.
    Original glass top and bottom with the original wood stays
    The label was printed by the Upton Brothers,Meriden Conn.Can anyone date the printers?
    Thanks,
    Bruce
