Soldering and heating with hot air
Discussion in 'Clock Repair' started by kinsler33, Sep 27, 2017.
  1. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    623
    Science teacher, writer
    Lancaster, Ohio, USA
    2 in 1 Soldering Rework Stations SMD Hot Air & Iron Desoldering Welder ESD 862D+ | eBay
    The oddly-worded URL above links to an eBay listing for a soldering device similar to the one I purchased last year without much forethought. The thing is way too big and weird, but it's very well made and I have recently found a use for its most obscure feature.
    Over on the left is a 'solder rework station' for electronic circuit boards that use surface-mount devices (which are generally horrible to anyone as old as I.) It's like a very small, very concentrated hair dryer, and it will emit a stream of air hot enough to melt tin-lead solder at the very least.
    When confronted with torn-off bezel hinges and glass-holding tabs and the like I'd used my grandmother's old 150 watt American Beauty soldering iron (she used it to make bomb fuses at the Chicago Coin pinball machine factory in World War II, in fact.) It's a noble old tool, but utterly awkward if you've got a hand tremor like mine.
    So the other day I tried the Solder Rework Tool, or whatever it's called, playing the stream of hot air onto the solder blob where the bezel hinge had been attached. It melted immediately. Then I soldered the old hinge in place, and it was the neatest job I'd ever done. That's because I didn't have to lay a tinned soldering iron tip against the brass bezel to heat the solder joint, and that meant that there was no little blip of solder to contend with after I was through.
    There may be many more applications of this here device, for it'll heat up a stuck part without a flame.
    M Kinsler
    Bill Stuntz and Time After Time like this.
  2. R. Croswell
    R. Croswell Registered User
    6,642
    23
    An interesting contraption and the price is 'right'. I like that it has (or claims to have) accurate temperature control. I have a huge old soldering iron like your grandmother's but I think 300 watt. I seldom use it for the same reasons. Thanks for sharing.
  3. Time After Time
    Feb 22, 2010
    3,107
    11
    Retired General Dentist
    Interesting. 500 degrees Celsius is pretty hot! Thanks for sharing.
  4. mldenison
    mldenison Registered User
    Oct 3, 2010
    101
    York, PA
    Very neat! I just bought one. I have 2 SMD clock projects, each with a couple of SMD's. Now, maybe I can try to finish them.
  5. Dick C
    Dick C Registered User
    Oct 14, 2009
    1,253
    Interesting machine.
    I have never soldered something like a hinge to the bezel, both brass. However, I am now in the learning mode and have read many of the posts in the forums, utilized the Internet, etc.
    Would you please describe the steps that you took after removing the old solder such as cleaning the two surfaces, if/how you applied flux, the type of solder that you utilized, how you might have clamped the two pieces together, whether you utilized the hot air device or the iron to heat the hinge (or the bezel), etc.?
    Thank you
    Dick
  6. Bill Stuntz
    Bill Stuntz Technical Admin
    Staff Member Donor NAWCC Member
    Apr 6, 2012
    4,090
    PC Tech
    Columbus. OH
    I just ordered one! My soldering station has been giving me trouble lately, and I need a new one anyway. And it should be useful for my part-time work as a PC tech, too. I occasionally need to re-flow the solder joints of surface mount graphics chips on laptop System Boards. The precision hot air gun should let me do that.
  7. bangster
    bangster Super Moderator
    16,313
    20
    I'd like to see a pic of this tool in action!
  8. Dave T
    Dave T Registered User
    Donor NAWCC Member
    Dec 8, 2011
    1,528
    retired accountant
    NC
    Yea, me too! Up til now, I've never been able to solder anything to my satisfaction!!
  9. wow
    wow Registered User
    Jun 24, 2008
    2,134
    Retired Music Minister
    Pineville, La. (central La.)
    I bought one after I read this thread. So far, I have only used it in a test to check it out. I had an old movement with a terrible solder job on the EW. It was soldered to the collet. Solder piled up. I turned on the hot air gun and gradually turned up the temp till the solder started melting. It blew the excess solder away and I removed the wheel easily. The soldering gun has several tips to choose from. The temp control feature is the best feature. I have only used it in a test mode so far, but I am glad I got it. I think it will be very useful in clock repair.
  10. Bill Stuntz
    Apr 6, 2012
    4,090
    PC Tech
    Columbus. OH
    I'm going to create a thread in the Tools forum with a link to this thread.
    Dave T likes this.
  11. kinsler33
    Aug 17, 2014
    623
    Well, to begin with, I didn't remove the old solder because it had held for about a century and had thoroughly tinned the surfaces.
    The solder was 60/40 tin-lead flux-core radio solder, about #18 gauge, that everyone used to use for electronics work. I'd tell you to find some at Radio Shack, but they're gone now. The stuff I have use now came from an electronics supplier now called MCM Electronics in Centerville, Ohio and was their house brand with the semi-pronounceable name "Tenma." In past years I've used Ersin Multicore solder, which might even be better. I know nothing about lead-free or silver-bearing solders because I haven't had to use either one yet.
    Now as for flux, I don't quite recall if I added a smear of Kester Soldering Paste and, if so, if I used the stuff I bought 20 years ago or the stuff my father bought 60 years ago: both cans are there in the drawer. It's a good flux for big stuff like bezels and other brass hardware, but do not use it on wires or they'll corrode apart in a year or so.
    The soldering technique consisted of (1) using the hot air stream to melt the existing lump of solder left on the bezel, (2) fluxing and adding a bit of solder to the tinned mating on the hinge, (3) lining up the parts and pressing them together as best I could, (4) heating up the whole thing until I was convinced that the solder on both sides had melted, which is sometimes tough to see and finally (5) continuing to hold the parts together until I was convinced that the parts had cooled enough for the solder to harden. All of which is to say that I used conventional soft soldering techniques, only with hot air instead of a soldering iron, and it worked.
    To press the parts together, which is always an interesting problem, I sat the bezel on a wooden block, laid the hinge atop it, and pressed down on the hinge with a screwdriver while I applied the hot air. This doesn't do the screwdriver a lot of good, but no harm seems to have been done.
    M Kinsler
    I might also mention that, as an experiment, I used the hot-air tool to blue the head of a nail.
    Mark Kinsler
  12. Dick C
    Oct 14, 2009
    1,253
    many many thanks
  13. bangster
    16,313
    20
    I wanna see pictures.:yoda:
  14. wow
    wow Registered User
    Jun 24, 2008
    2,134
    Bang, here's one on YouTube. Not about clock repair, but pretty good illustration. There are many other on YouTube.
  15. shutterbug
    34,341
    30
    #15 shutterbug, Oct 12, 2017
    apparently you can't watch that one unless you go to Youtube. (edit: clicking on the "watch this on Youtube" link seems to work)
    This one shows what it can do.
  16. kinsler33
    Aug 17, 2014
    623
    That's approximately the machine I have, and I wonder if the maker of the video understood that you can use its hot air gun for soldering and intense heating as well as just for heat-shrink tubing.
    I'd have taken pictures of my own bezel-hinge soldering with the hot-air gun if I'd had any confidence that I knew what I was doing, which I didn't. It worked far better than I thought it would, and the Chinese variety seems perfectly adequate for clock work.
    M Kinsler
  17. shutterbug
    34,341
    30
    #17 shutterbug, Oct 18, 2017 at 11:40 AM
    I ordered one, and just got it. The main features are
    1) It heats up and cools down crazy fast! Waiting for the old style heaters to get to temperature was frustrating!
    2) It holds the set temperature throughout the process
    3) Wide selection of soldering tips and heat gun tips
    4) Easy removal of multiple solder point objects (like chips) with the heat gun.
    5) Good gun and solder tool holding fixtures
    6) Very good safety features (the air gun cools down automatically when placed in it's holder, so you don't start any fires)
    I have not yet tried the heat gun for heating big stuff like bezel hinges, but I think that will be a much easier project with it!
    There are several videos on Youtube using the machine. Search for "SMD Rework Station 862D+" to watch some of them.
    I've noticed that there is more than one name for the same machine in the video's. As long as it's the 862D+ they are the same machine.
    I also noted that the ones in the video have a clamp fixture to hold the various gun tips to the heat gun. Mine has a newer 'screw on' feature which looks faster and better.
    I'm envisioning the air gun as a great tool for keeping hot glue pliable as you position objects too!
  18. wow
    wow Registered User
    Jun 24, 2008
    2,134
    Shop around. I got mine at a great price. There are many from which to choose.
  19. Bill Stuntz
    Apr 6, 2012
    4,090
    PC Tech
    Columbus. OH
    Mostly in the $50 ballpark. After I ordered mine, I saw one for about $5 cheaper. So I should have shopped around a little. I just got mine and haven't actually used it yet, but I'm convinced that it will be a very handy gadget.
  20. wow
    wow Registered User
    Jun 24, 2008
    2,134
    On eBay for less than 40 with free shipping.
  21. kinsler33
    Aug 17, 2014
    623
    Ulp.
    I sure hope everyone likes their machines. Otherwise I suppose you can blame me.
    I've been using mine to re-construct a warning lever that I somehow managed to lose off a grandfather clock movement. I re-strung the chains, set it up on the test rack, started the pendulum, admired the nice vigorous pendulum motion, and behold: there is no warning lever and no e-clip on its pivot post. I have a photograph of the movement with the that lever, so I know I had it and I know roughly what it should look like. And I have torn the place apart in the search.
    In any event, I'm getting better at soldering, and learning just how an Urgos chime auto-correct works.
    M Kinsler
    rats
  22. Bill Stuntz
    Apr 6, 2012
    4,090
    PC Tech
    Columbus. OH
    I KNEW that machines like that existed. And I assumed they'd be out of my price range until I looked into them because of your post. Thanks! :mytnx: So yeah, I DO blame you. But "credit" might be a better way to say it.
Similar Threads - Soldering heating Forum Date
Re-soldering a two piece mainspring barrel Clock Repair Jul 23, 2017
Please step away from the soldering iron... Clock Repair Jul 12, 2017
Soldering a Bezel to a Dial - Is There Another Method Clock Repair Jul 11, 2017
soldering spring slips on fusee pallet Clock Repair Sep 19, 2016
heating and hammering brass Clock Repair Jul 17, 2007
