I’m new to the ultrasonic cleaning world. I haven’t actually taken the dip yet, but I’ve spent several hours on these NAWCC forums trying to educate myself on the proper cleaning solution(s) to use. I know this is a well-worn subject with lots of varying opinions.
I’ll be cleaning not just movements, but also a number of brass crystal regulator cases. Since some of these cases are lacquered, I’m thinking an ammoniated US cleaning solution would work well for me because I’d like to remove the old lacquer.
If I’ve understood several past posts correctly, Historic Timekeepers was a popular ammoniated cleaner. But apparently it’s no longer available. I’ve seen a few other posts which seem suggest or suspect that Magic Cast (available thru Timesavers) is merely a marketing name-change, and that the two solutions are essentially the same, if not identical, products.
So this is my long-winded way to ask: Does anybody really know? And regardless of whether they are in fact the same, can anyone share their experiences with Magic Cast—especially in comparison to another popular cleaner, DEOX-007 (which I understand is non-ammoniated).
Thanks in advance.
Thanks in advance.
