Smoothing Broaches, making your own •
Discussion in 'Hints & How-to's' started by Jay Fortner, Feb 6, 2014.
Thread Status:
Not open for further replies.
  1. Jay Fortner
    Jay Fortner Registered User
    Feb 5, 2011
    5,023
    24
    Clockmaker/Watchmaker
    Chiefland,Fl.
    #1 Jay Fortner, Feb 6, 2014
    Here's how I make my own smooth broaches;
    Start off with a piece of hardened pivot wire in the size range of the hole you're broaching.
    Chuck it in a drill and hold it against the side of a spinning grinding wheel at a very slight angle,less than 1deg(1 deg=.0175 per inch taper).
    Using progressively finer sand paper run the drill and smooth the grinding marks while maintaining a crosshatch pattern on the broach,if a little cutting action is desired stop at the coarser grit paper.
    This is what your finished broach should look like. The camera didn't pick up the crosshatching very well but it's there.
  2. bangster
    bangster Moderator
    19,293
    328
