Hi - I am trying to repair a Smiths pendulum wall clock for my daughter and son-in-law. About 3 years ago they had it totally overhauled at some considerable expense but recently it stopped working. I discovered that the suspension spring was broken and have purchased a new suspension as near as possible with the same dimensions but the clock will still not work. I have tested the main spring and, although I haven't taken the clock apart, it seems to have plenty of power. I took the pallet off and when the spring is wound a little the main train works well. However, when I re-assemble the pallet arm and suspension with the pendulum the clock will only tick for a few seconds. When I take the pendulum off then the clock ticks away at speed. Could it be that I have an incorrect suspension? - I obviously do not know what it would originally have had but maybe the previous repairers fitted a wrong suspension. Any thoughts, once again, greatly appreciated. The clock has obviously had some rough repairs in its history!!
Timbo 19
Timbo 19
