Smith Enfield Time and Strike Verge question
Discussion in 'Clock Repair' started by THTanner, Jun 12, 2019.
  1. THTanner
    THTanner Registered User
    NAWCC Member Donor
    Jul 3, 2016
    2,607
    191
    Carson City, Nevada
    This is a Smith Enfield time and strike mantle clock movement.
    It appears that the verge has been filed in the past to remove the usual groove wear. In that process it looks like they made an angled face that is sloped a bit steeper than what I usually see on a verge like this.
    Does anyone know if that small angled area at the end is supposed to be there on an Enfield, or should it be flat all the way to the tip?
    thanks
  2. bruce linde
    bruce linde Technical Admin
    6,585
    742
    oakland, ca.
    my gut reaction to that first photo:
    and then see what you've got, and how it runs.
  3. THTanner
    NAWCC Member Donor
    Jul 3, 2016
    2,607
    191
    Carson City, Nevada
    LOL - that is how it came in - it is totally apart and cleaned - the face on the verge is the only issue left. There is some of the old groove still on the flat part and a new groove cut into the angle that I don't think is supposed to be there.
  4. bruce linde
    6,585
    742
    oakland, ca.
    can't see the verge/pallets interaction without video, but... any way to move the escape wheel slightly to avoid the ruts?
  5. THTanner
    NAWCC Member Donor
    Jul 3, 2016
    2,607
    191
    Carson City, Nevada
    It could be moved a bit, but the little slope at the end goes all the way across, so if that is not correct then moving the EW does not really solve the issue. I would be inclined to try that except that the final slope cut is not very precise and looks like a bad file job to cut out the old groove. It also is quite soft, so I think it was annealed then not hardened again. I have never seen a verge shaped like this so I suspect it is not correct. A rough measure of the final slope is about 20 degrees from the flat part.
    I think I will proceed to flatten all the way to the end to take out the groove and see how it runs. I can bend that end of the verge a little if it looks like it needs a bit of an angle there. If it runs well I will finish polish and re-harden. I think the main effect will be on the amplitude of the pendulum swing once it is set to the proper depth.
  6. chrisuk
    chrisuk Registered User
    Sep 4, 2010
    76
    10
    Clock repairer & organist
    Staffordshire , UK
    Enfield pallets look like this, I've repaired many Enfield/Smiths clocks.
    Hope this helps.
    Chris
    THTanner likes this.
  7. shutterbug
    43,233
    1,191
    The sharp angle back cut on the entrance pallet won't hurt anything. You want a sharp drop off, and the angle isn't very important. The grooves can be an issue. After removing them, the pallets need a bright polish.
  8. THTanner
    NAWCC Member Donor
    Jul 3, 2016
    2,607
    191
    Carson City, Nevada
    thanks - that is what I am aiming for -
    any special issues or advice on hardening? I usually get to a dull red then quench and only worry about the contact area
  9. shutterbug
    43,233
    1,191
    I think that will work for pallets. It will be super hard though.
