Small, Early? Bakelite
Discussion in 'Your Newest Clock Acquisition' started by ScotSun, Jan 7, 2018.
  1. ScotSun
    ScotSun Registered User
    Nov 28, 2017
    58
    Computers
    Newark, DE
    I found this little guy sitting lonely on a back shelf of one of those antique malls that are so cluttered with rubbish that you don't know where to look. I normally glance over smaller clocks but something made me pick this one up. Maybe it was the exposed mainspring movement, but for $8, I thought it would be a nice little thing to learn more on.
    It appears to have a watch spring movement, the mainspring is broken and the bakelite case is also cracked. There are no marks that I can see anywhere on it. Anyone have an idea of manufacturer? Year?
    20180107_160833.jpg 20180107_160840.jpg 20180107_160849.jpg 20180107_160859.jpg 20180107_160907.jpg 20180107_161017.jpg 20180107_161029.jpg 20180107_161833.jpg 20180107_162829.jpg
  2. JTD
    JTD Registered User
    Sep 27, 2005
    7,923
    571
    For $8 you got a nice little clock, I suspect the movement is German although I can't identify the maker.
    I don't think the case is bakelite, I think it is celluloid, judging by the appearance and the cracks and splits. There were a number of little clocks made with celluloid cases in the 1930s, often white or cream, but I forget now who made them.
    Sorry to be so vague - hope someone else will be along soon with better information.
    JTD
  3. chronologiker
    chronologiker Registered User
    Jun 28, 2017
    360
    27
    #3 chronologiker, Jan 8, 2018
    I agree with JTD: The movement is most likely German and the case material is not bakelite. Could it be made of synthetic resin?
    The movement reminds me Fichter KG. Please tell me the diameter of the movement.
    Chronologiker
  4. Kevin W.
    Kevin W. Registered User
    22,623
    392
    If you are looking for a clock to learn on, there are better choices.
  5. ScotSun
    Nov 28, 2017
    58
    Computers
    Newark, DE
    Thank you all... In regards to learning... I like to try all kinds of things and if I screw something up on an $8 clock, I won't be too upset. The case was pretty much trashed but I have now disassembled it and ordered a new spring. Going to do some cleaning and see if I cannot get it functioning. I have now worked on a pair of Seth Thomas clocks, one pre-1900 and the other in the '20s. This one is interesting as it has a watch spring and not a pendulum...
    The plates are 2.125 Inches across.
  6. JTD
    JTD Registered User
    Sep 27, 2005
    7,923
    571
    Don't be too quick to write off the case. From what I can see It doesn't look too bad to me and certainly not beyond repair/use. And you won't likely find another empty one in better condition. I hope you will keep it - and these celluloid (for that is what I think it's made of) cases polish up nicely.
    JTD
  7. rmarkowitz1_cee4a1
    Nov 26, 2009
    5,344
    944
    I believe that the case of your clock may be catalin rather than celluloid or bakelite. Catalin and bakelite are actually 2 different forms of early plastic though objects made from either are often called "bakelite".
    Bakelite is made from formaldehyde, phenol and a filler for added strength which included things like rags, cotton and even asbestos! It is heat resistant and was used for everything from pot handles to radios to clock cases, etc. and so on.
    Though reinforced so less prone to cracking, its major draw back was that it was brown or black. Not very appealing.
    Catalin was produced by the American Catalin Co. It is a resin made with formaldehyde and phenol. It can be dyed bright colors, marbleized, etc. It was not reinforced so it does tend to crack as your clock's case did.
    Celluloid is a plant based form of early plastic. It is generally an ivory color with fine striations. Celluloid clocks are not uncommon.
    I rooted around the internet and found this about catalin and bakelite : Bakelite & Catalin: All you need to know + Testing | eBay
    Though it was pretty good. Take a look. Dates when bakelite and catalin were introduced, produced, how to test for them, etc.
    RM
    ScotSun likes this.
  8. ScotSun
    Nov 28, 2017
    58
    Computers
    Newark, DE
    I do not know if you noticed in my previous but...
    The plates are 2.125 Inches across. Although the face was oval, the movement plates are circular. If any of that helps...
