Slow striking
Discussion in 'Clock Repair' started by Clockinit, Nov 20, 2019.
  1. Clockinit
    Clockinit Registered User
    Nov 4, 2019
    100
    People...Dad's clock is back up and running...All strikes are striking correctly and the beat is set and the crutch adjusting wheel peg is now in the correct position ..Had plenty of input from obviously knowledgeable people...Now my issue, before I do final assy, is the hour strikes are really pretty slow. Chimes seem up to speed...just to re-itterate. this was the 50 year old Emperor Clock kit with the Erhardt Jauch movement...Thoughts please.....
  2. JimmyOz
    JimmyOz Registered User
    Feb 21, 2008
    225
    27
    First thing to check, you have the 2nd heavest weight on the strike and the lightest on the time if they are different?
  3. Clockinit
    Nov 4, 2019
    100
    Yes Sir, they are correct......
  4. Willie X
    Willie X Registered User
    12,026
    703
    How high are the hammers being lifted? It shouldn't be more than about 3/4".
    WIllie X
  5. JimmyOz
    Feb 21, 2008
    225
    27
    How slow are they, think Big Ben, they do not run as fast as the chime anyway, a clear 'dong' then time to stop vibrating before another. If the time between each 'dong' is different then it could be a problem, however if the time between is about the same it may be set up at that interval?
  6. Clockinit
    Nov 4, 2019
    100
    The 'dong' spacing seems very similar on all of them. . Is there an adjustment for the hammer lift? Because the hammers are definitly being lifted more than 3/4"...Just to be clear, is that 3/4" or
    3-4 inches? Because the lift IS 3-4 inches... newpicsclock1.jpg newpicsclock2.jpg newpicsclock3.jpg
  7. Willie X
    12,026
    703
    That thumbscrew should adjust the stroke length. Once the stroke length is correct, the distance from the hammers to the rods will need to be re-adjusted.
    The hammer wires are already bent way foward. So, it would be best to straighten the rods and reposition the hub on the hammer shaft, if possible.
    You could go for a 1 1/4" stroke on that clock for starters.
    If you have a 4" stroke, someone may have monkeyed with the lifting mechinism in an effort to get more volume?
    WIllie X
  8. lpbp
    lpbp Registered User
    NAWCC Star Fellow NAWCC Life Member
    Aug 25, 2000
    2,844
    You may not have enough power does the clock need bushings, or if you did that you may have a bad one, these movements wear badly and that could be a problem.
  9. Willie X
    12,026
    703
    What is the actual weight of the strike weigh you are using? I have an original Jauch (77?) clock I can check. I can also check the striking rate per 10 seconds, if you are intetested. Willie X
  10. shutterbug
    40,812
    732
    Also the lift lever needs a nice polish. If you have grooves cut into it, it will need to be refaced or replaced. You can make a decent replacement by hammering out some steel wire into a paddle shape and inserting it like it is now. Hardening it is optional, but it will last longer if you do. Also check that the lift wheel teeth are smooth and not bent at the tips.
  11. Clockinit
    Nov 4, 2019
    100
    I will double check the weight...I shortened the lift on the hammers to the rods and there seems to be a little difference in speed. Almost to the point, I can live with it...considering the age... I was wondering if There was more weight on the Strike weight. I read in one of Steve Conovers books that ADDING minimal weight, say 15% is acceptable...Thoughts...
    Ipbp...This movement absolutely has wear. It is 50 years old,and I gotta believe Dad never re-bushed it...
  12. Clockinit
    Nov 4, 2019
    100
    Willie X...the strike wight is 7.8 lbs...
  13. Dick Feldman
    Dick Feldman Registered User
    Sep 1, 2000
    2,128
    79
    Colorado, usa
    That is not a Jauch 77 movement. It is the large frame, thick plate triple chime movement.
    Weights should be near:
    Time: 7 LB, 3 Oz
    Strike: 7 LB, 11 Oz
    Chime: 10 LB, 9 Oz
    Being old will not make a movement need bushings.
    Being old and having been run a long time will.
    If the movement has never been run, it should not need to be bushed.
    You seem to have a power issue.
    Maybe that is due to a bent pivot or not enough arbor end play (called end shake with clocks)
    I have found these movements to not have sufficient arbor end play when near new.
    You will be looking for causes of excessive friction.
    Dick
  14. Clockinit
    Nov 4, 2019
    100
    Yes, it is the larger Erhart Jauch movement
  15. JimmyOz
    Feb 21, 2008
    225
    27
    Do a quick check of the pivot holes, take the weight off, start on the bottom wheel and move it back and forth and look for any play, do the same to all the wheels. You can also try lifting the rack stop lever and let it run as when you cleaned it you may have left a bit of gunk in a pivot hole and the momentum it builds up may be enough to clear it out. I don't think it is a slightly bent pivot as the fly would go slow and fast.
  16. Willie X
    12,026
    703
    I don't have one of those but the big Urgos movements of that time period did normally strike slowly.
    The word 'slow' is not very helpful. 10 strikes in xx seconds would ne more helpful.
    WIllie X
  17. Clockinit
    Nov 4, 2019
    100
    Thanks guys ...will do all that after chow...
  18. Clockinit
    Nov 4, 2019
    100
    So guys...did all the above and Strikes are liveable...11 strikes in 17 seconds....every 1.5 seconds...I'm good with that.there's a noticeable difference....Again Thank You-Thank You for the help
    Last issue....Then i wanna seal this puppy up, and clean up the case and move on to the next project....
    Pendulum Wobble...The suspension spring is new...I saw Merrits advertising in their catalouge a heavy duty suspension spring to eliminate pendulum wobble..How will that affect the running of the clock?...
  19. Uhralt
    Uhralt Registered User
    3,872
    388
    #19 Uhralt, Nov 22, 2019
    If the suspension spring is new and not kinked, it is likely not causing the problem. More likely the crutch fork isn't pushing the pendulum rod exactly parallel to the movement plate. Make sure that the fork isn't bent sideward. Another reason might be that the suspension spring has too much play where it the upper end is attached. Then the slot needs to be tightened, but not too much. The spring must still be able to move forward and backward without too much friction.
  20. Willie X
    12,026
    703
    Thats a normal strike speed for a big clock. I dont think you need a "heavy duty" spring, just a new spring that fits should do it. Willie X
  21. Dick Feldman
    Sep 1, 2000
    2,128
    79
    Colorado, usa
    The post that comes off of the rear of the crutch should be perpendicular to the rear plate of the clock. If that is “pushing” the pendulum on an angle, it can cause the pendulum to wobble.
    If the pendulum bob is not parallel to the rear plate when resting, every time the crutch pushes the pendulum it will have a tendency to make the pendulum wobble. Is your suspension spring twisted?
    Me thinks the strike train on your movement is operating too slow and that condition will likely become worse with time and eventually fail. A sequence of one strike per second or less would be more acceptable. Look for friction in the strike train like a tight pivot in a hole, a bent pivot, etc.
    JMHO.
    It is hard to get to the crux of the posts with all of the *!#%^&(+ ads.
    Dick
  22. Clockinit
    Nov 4, 2019
    100
    OK!...so on close, close inspection the Crutch fork was 'twisted' ever so slightly. the peg needed to be bent downwards, ever so slightly, the slit in the post needed to be closed up and the bob to the pendulum was so, so ever out of whack....all those Adjustmentd and I have ZERO wobble...WOW!!!...THaNKS TO ALL!!! I"M putting the back and side access covers on, cleaning the case & calling it a DONE deal!!! I will be back here when I start my next project,,, Got my eye on a HOWARD MILLER....No pendulum, no weights...Supposedly 'RUNS GREAT' We'll See...Will get back to you Guys...YOU ROCK!!
