Slick 50® One Lube®
Discussion in 'Clock Repair' started by Jake SD, Jun 13, 2014.
  1. Jake SD
    Jake SD Registered User
    May 11, 2014
    29
    I'm new to the forum so I hope I am posting correctly. I've been reading a lot about Slick 50 One Lube for mainsprings.
    I'm working on my first clock movement. My question is, can One Lube be used lubricating all of the clock mechanism?
    I do have clock oil.
    Thanks.
  2. shutterbug
    shutterbug Super Moderator
    37,009
    186
    Re: How to oil a clock
    Nope. Use it for mainsprings, but nothing else. Your clock oil will be better for pivots.
  3. Jake SD
    May 11, 2014
    29
    Thank you, shutterbug. One more question, between the hour hand and the minute hand, there is a washer. Do I put oil in this area?
  4. shutterbug
    37,009
    186
    Nope. :)
  5. harold bain
    harold bain Registered User
    NAWCC Fellow NAWCC Member Donor Deceased
    40,850
    114
    deceased
    I've often wondered that myself, but haven't tried it. If it is your own clock, why not give it a try? Don't spray the movement, just catch some oil in a cup then use a pin oiler, or a toothpick to oil the pivots.
  6. shutterbug
    37,009
    186
    If you do that, please post the results and post again if any issues arise :)
  7. Jay Fortner
    Jay Fortner Registered User
    Feb 5, 2011
    5,019
    23
    Clockmaker/Watchmaker
    Chiefland,Fl.
    I have been experimenting with Slick1 as a pivot and pallet lube for a couple months now. It seems to be doing a good job on pallets and pallet pins in both pend. and flywheel clocks and small low power pivots such as EW,lever pivots,roller and balance staff pivots in flywheel clocks. When using it as a pivot and pallet lube it's best applied as a thin film. As Harold suggested spray it out into some kind of small container. Then using a clean toothpick apply it in the pivot hole or on the pallets during assembly.
    This is in the test stage so anyone reading this should not try it on someone elses clock.
  8. bangster
    bangster Super Moderator
    17,593
    96
    #8 bangster, Jun 18, 2014
    Re: Slick 50® One Lube
    I think I recall that aerosol Slick1 is one of those where the carrier liquid soon evaporates, leaving behind the teflon (or whatever) bits to do the job. If that's the case, it might be less effective in low surface-area situations like pivots.
    Strictly speculation on my part. Take it for what it's worth.
  9. John Hubby
    NAWCC Star Fellow NAWCC Life Member
    Sep 7, 2000
    11,933
    93
    The Woodlands, TX
    #9 John Hubby, Jun 19, 2014
    Bang, the original formula for Slick 50 One Lube did contain "collodial" Teflon® that would not settle out with time (I tested this myself), but even back then the carrier oil did NOT evaporate. It was a low viscosity synthetic/natural blend very similar to your regular clock oil, the propellant in the spray cans was a propane/butane mix which does evaporate as the spray is applied. The claimed purpose of the Teflon® was to adhere to the bearing surfaces providing a much lower friction surface than can be obtained using "just oil", same claim as made for the original Slick 50 HP Synthetic with Teflon®. The particle size of the Teflon® was claimed to be sub-micron, if so you would not see any evidence of clogging up pivots or mainsprings or the like.My personal experience with the original Slick 50 HP Synthetic shows 20+ years closed-barrel mainspring service without any lubricant deterioration or needing to be re-lubricated, by actual test. The clocks under test have been opened every five years for inspection, the last time was in 2013 and I'm not going to open them again until the clocks stop from lack of lube on the pivots. The pivot oil (Etsyntha 859 synthetic) does seem to disappear after 10 years or so.Slick 50 the company lost a final legal battle with DuPont within the past five years that resulted in them removing Teflon® from all their products. Their other additives (composition unknown) continue to be included, and my digging into this indicates they changed the synthetic/natural oil blend ratio to one with less synthetic. I don't know the ratio but am guessing it's now about 85% synthetic 15% natural. Both the synthetic and natural are compatible relatively short-chain aliphatic compounds that are highly resistant to chemical or heat breakdown. The present Slick 50 One Lube does seem to perform as well as the Teflon® version at least for four years (that's how long I've had it on test, mainsprings only).Note that the results I report here are primarily in service with torsion pendulum clocks . . 8-Day, 30-Day, 400-Day, and 1000-Day. I also have some 14-day French conical pendulum clocks running that exhibit similar performance as the torsion clocks.
  10. bangster
    17,593
    96
    #10 bangster, Jun 19, 2014
    Hey John...Thanks very much for the update and correction. Faulty memory is never a decent substitute for accurate information.
  11. MuensterMann
    MuensterMann Registered User
    Mar 23, 2008
    1,002
    "The pivot oil (Etsyntha 859 synthetic) does seem to disappear after 10 years or so," John says.
    I have been curious about this. So, when the pivot oil disappears, do you add more oil? Of course, when it disappears there is something that remains in the form of dirt and dried oil. I have learned with my bicycle chain that you must clean the chain first before applying more oil - otherwise you are just adding oil to a dirt/grime layer.
    The curiosity is also there about "having a clock serviced". Service may include adjustments, but does it also mean adding oil to the pivots? If so, is that really a good thing to do (see paragraph above)?
  12. shutterbug
    37,009
    186
    Many advise oiling after five years, servicing again after 10.
  13. Jay Fortner
    Feb 5, 2011
    5,019
    23
    Chiefland,Fl.
    I recommend reoiling every two years and service intervals depend on environmental issues. For clocks that reside in nice clean houses and neighborhoods with paved streets and grassy lawns then you could get by with servicing in ten year periods. In areas with dirt roads and sandy landscapes five year service intervals would be better. No one service period applies to all.
  14. shutterbug
    37,009
    186
    Good point, Jay. We tend to judge things from a narrow perspective based on our own situation instead of the global family that we are :)
  15. MuensterMann
    Mar 23, 2008
    1,002
    Okay, so "servicing a clock" means disassemble, clean, reassemble and lubricate a movement? Then, the re-oil in the meantime is simply called "oiling" which is just the pivots and whatever else that does not require disassmbly of the movement?
  16. Jay Fortner
    Feb 5, 2011
    5,019
    23
    Chiefland,Fl.
    That's the idea. On some of the more complicated movements some disassembly is required to get to hidden pivots but you wouldn't split the plates.
  17. bangster
    17,593
    96
    Oiling MUST include the front plate. Either take the movement out, or take the dial and bezel off. Otherwise, you're only half-oiling.
  18. MuensterMann
    Mar 23, 2008
    1,002
    Thanks for the input!!
  19. paul830
    paul830 Registered User
    Jul 14, 2012
    John, What are your thoughts about using Slick 50 on an Atmos mainspring? Thanks, Paul
  20. Les Sanders
    Les Sanders Registered User
    NAWCC Member Donor
    Apr 3, 2010
    583
    Clock Repairman
    Sahuarita Arizona
    I now use Slick 50 Original on all Mainsprings, And Mobil 1 0W - 20W on all pivots, except platform escapements I use watch oil! No problems have been noticed.
  21. Jay Fortner
    Feb 5, 2011
    5,019
    23
    Chiefland,Fl.
    Not speaking for John but Slick 1 will perform well on light mainsprings like used in Atmos clocks. I have changed to STP for medium to heavy mainsprings with very good results.
  22. David S
    David S Registered User
    NAWCC Member Donor
    Dec 18, 2011
    6,592
    86
    Brockville, On Canada
    Hi Jay,
    Haven't seen you around much lately. Miss your contributions. When you say STP, what exactly are you using? Around here there are lots of STP products.
    David
  23. Jay Fortner
    Feb 5, 2011
    5,019
    23
    Chiefland,Fl.
    The original oil additive. Thick and slicker'n snot. Remember the 70's TV ad where the sumo wrestler couldn't hold the tip of a screwdriver that had been dipped in it? That stuff. Mainsprings wind up and let down like silk.
  24. MuensterMann
    Mar 23, 2008
    1,002
    Has anyone ever tested the new Slick 50 formula for use on mainsprings? My old can finished and only new formula on the shelves. I bought it to use as well. We shall see!
