Slate clock detail gilding help
Discussion in 'Case Construction, Repair & Restoration' started by bazas, Jul 6, 2019.
  1. bazas
    bazas Registered User
    Dec 3, 2015
    45
    Hi
    I have a beautiful french slate clock that I would like to gold leaf the detail. I have found a lot of tutorials on gilding but nothing on slate clocks.
    The clock has been blackened.
    So do I need a primer on the detail before gilding.
    Thanks Baz
  2. wcampbell
    wcampbell Registered User
    Nov 25, 2013
    32
    19
    Aircraft Mechanic / Contractor
    Wiesbaden Germany
    If you really want to use gold leaf you will want to make sure that the scroll work is clean and free of contaminants.nice clean lines. Sizing is used as the medium to adhere the gold leaf. It is kind of tricky to use. it has to dry to a point but not to much. Too dry and the gold leaf won't stick to tacky and it can get messy. for scroll work it can be challenging. I just finished a Seth Thomas Adamantine had a lot of scroll work on it that i posted. I had my reasons why I didn't use gold leaf and chose to use a metallics acrylic gold paint. I Used a very fine brush to apply the metallic Acrylic paint into the scroll work. After maybe 7 to 10 mins. I dampened a blue shop towel and began to rub the scroll work the paint stayed in the scroll work and It cleaned up extremely well and left very clean lines. I have to say I was very happy with the outcome.
    bazas likes this.
  3. bazas
    Dec 3, 2015
    45
    Thanks, I finished a clock recently as well it was an Ansonia El Pino clock and I did all the detailing in antique gold acrylic on that one. I was pleased with the result however I wanted to try to add 24K gold to the detailing instead this time.
    Do you know if I would need to use a primer on the lines first before adding the size. Its the first time I have used gold leaf.
    I have added a picture of my Ansonia El Pino I completed recently.
  4. wcampbell
    Nov 25, 2013
    32
    19
    Wiesbaden Germany
    As long as the Scroll impressions are cleaned out you should not have to use a primer. In traditional methods of gilding an object the yellow primer that you get with gilding kits is used to level out surfaces and give you a better surface to apply the size and gold leaf over large areas. In this case you are applying the size and gold leaf in such a small area that by adding a primer, depending on the primer's viscosity could inadvertently fill the scroll impressions causing you to loose some of the fine scroll detail. However there are gold leafing pens that time savers sell that you could try. I bought one but never tried it. instead I opted to use the paint. it is an 18kt. gold leafing pen
    bazas likes this.
  5. Joseph Bautsch
    Dec 9, 2006
    1,113
    125
    Atlanta, GA
    I've used both the pen and the guilding methods described above. wccampbell is right on. Do not use a primer. Apply the gilding sizing using a small artist brush. Keeping as much of the sizing in the grove as possible. It will spill over the sides but will be easier to clean up afterwards. Let the sizing dry about 20 minutes (read the directions for the application drying time on the sizing container). Do not try to rub the gold leaf on. "Press" in place using a fine but stiff brush. In the areas that it does not take reapply the sizing and do again. Let dry at least 24 hours or longer. The sizing does not dry as fast on stone than on other types of applications. I've has success using #0000 steel wool on stone for clean up. Gently buff over the groves until the areas around the groves come up clean. Do not press too hard or you will pull up the guilding in the groves. Using a gold pen is the same procedure. I've found that the pen needs to be held near upright to get a good flow of the paint. Drag the tip to apply never push. I've had the best success with the fast drying oil based paint pens. These can be found at a local artist supply store or on line. The two most critical points to remember is a "clean grove" and "drying time". The guilding nor the paint will adhere to dirty groves very well, and if not completly dry, will either pull up or collect a lot of crud trying to clean it up.
  6. shutterbug
    43,167
    1,182
    Gold leaf can also be applied with a brush. I cut the brush part off about 1/2" from the bottom, and use the brush to tamp the leaf into place. That way you can get it into the small crevices and get a very nice end result.
  7. bazas
    Dec 3, 2015
    45
    Thank you. The size I have has only one instruction which is wait till it goes tacky, Not too helpful on fine detail lol. I have been practising on an old box with branded detail and I seem to be getting the hang of it.
    I have used slate blackening on the case, I read somewhere that I would have to scrape out the blackening from the detail but I am unsure on this. Have you ever done this or just gild over the blackening.
    Thanks, I build detailed models as well so I have plenty of small brushes about thankfully.
    Thanks everyone, all your help is invaluable.
  8. Joseph Bautsch
    Dec 9, 2006
    1,113
    125
    Atlanta, GA
    I would clean out the blackening. I don't know how well the guilding or the gold paint will take to it. You may try experimenting with it to see how applying the two over the blackening will work. Sounds like you have a good handle on getting this done. When finished ake a photo and post the results.
    bazas likes this.
  9. bazas
    Dec 3, 2015
    45
    Ok I have almost gilding finished a small area of detail but I am unsure on how it looks. I was hoping for some opinions.
  10. Joseph Bautsch
    Dec 9, 2006
    1,113
    125
    Atlanta, GA
    I assume this is guilding not gold paint. If that is the case it looks like some areas took better than others. Apply a second layer to what you have.
    bazas likes this.
  11. gleber
    gleber Registered User
    Jun 15, 2015
    1,731
    193
    Underwater Robotics Expert
    Downingtown, Pennsylvania USA
    The edge detail looks good, but the center looks bumpy. Was the area within the incising cleaned well? If gilded, what did you use to press it in place?
    Tom
    bazas likes this.
  12. bazas
    Dec 3, 2015
    45
    Yes its gilding. I have been using a flat stiff brush that was supplied with the kit to push the gold in to the incising. I used a dental pick to clean the incising however the instructions with the gilding kit are sketchy at best. I have cleaned some out that I wasn't happy with and started again this morning. Hopefully it will look a bit better.
  13. gleber
    Jun 15, 2015
    1,731
    193
    Good luck. I hope it goes better. Keep us posted and let us know what you did differently.
    Tom
    bazas likes this.
  14. bazas
    Dec 3, 2015
    45
    This time I tried to use a hypodermic needle to put the size in to the incising, this seemed to work a bit better however trying to get size into the fine points on the detail is a nightmare, I have tried different methods using a needle, a hypodermic needle, a cocktail stick and the point of a dentist pick. i just cant seen to get the size to stay within the boundaries of the detail. I also left the leaf on the detail for a few hours before brushing away the excess and this helped a little as well.
    Here is yesterdays attempt, It looks great from a distance but as I get closer I can see the imperfections. I think I will give it one more attempt though.
    I have been considering just using an gold acrylic paint as I did with the Ansonia 'El Pino' Clock, Although I may use a Gold colour this time instead of Antique Gold. Here's a pic of the detail on the El Pino
  15. Joseph Bautsch
    Dec 9, 2006
    1,113
    125
    Atlanta, GA
    You may get better results using gold paint.
  16. bazas
    Dec 3, 2015
    45
    This is starting to be my thinking as well. I really wanted the 24k gold in there though so I have had another thought of crushing a Gold leaf to a powder and adding it to the Gold paint. I know it’s not the same as gilding but it would add the 24K Gold to the case. I am going to test this idea on some scrap first to see if would work out ok.
  17. shutterbug
    43,167
    1,182
    #17 shutterbug, Jul 14, 2019
    At any rate, it stands out much better than the areas without it. You have to get pretty close to see any problem.
  18. bazas
    Dec 3, 2015
    45
    Well I gave up on the gold leaf and I couldn’t grind the leaf to a fine enough powder to mix with the paint.
    So I have opted for Gold paint and the lines are much cleaner.
    PatH likes this.
  19. Joseph Bautsch
    Dec 9, 2006
    1,113
    125
    Atlanta, GA
    Yes, that looks really good. Neat job.
  20. shutterbug
    43,167
    1,182
    Yes, very nice! Well done.
    bazas likes this.
  21. gleber
    Jun 15, 2015
    1,731
    193
    It's too bad that you couldn't get good results with gilding. It would have made a nice case study for the rest of us if you figured it out.
    But, I'm glad you were able to achieve good results. Your results look great. Nice job.
    Tom
    bazas likes this.
  22. bazas
    Dec 3, 2015
    45
    Well I have just finished the painting of the detail and with more practice I may be able to do the gilding.
    I did find some information on Shell gold which I may look in to for the next clock.
    Thank you everyone for your help. I will post the final picture on here at the end of the week of the finished clock.
    PatH and Time After Time like this.
  23. Joseph Bautsch
    Dec 9, 2006
    1,113
    125
    Atlanta, GA
    That looks really good. I don't think any one will be able to improve on it.
    bazas likes this.
  24. shutterbug
    43,167
    1,182
    What does the plaque say?
  25. bazas
    Dec 3, 2015
    45
    The plaque says " Presented to Ex. P.C.. H.Hall.P.Div By The Officers and Men of the Lewisham Sub Division As A Token of Their Respect and Esteem On His Retirement after 25 Years Service on 14th Sept 1902"
    The Clock is now 99% complete, I just need a minute hand.
    As the case didn't have a movement I sourced an A.D Mougin Movement with dial, back, pendulum and gong. So all the numbers match.
  26. Paul Arsenault
    Paul Arsenault Registered User
    Jan 21, 2007
    526
    Sales
    Maryland
    Just looking through some of the older posts and thought I'll share a picture of my slate clock. The gold was just about completely gone from this clock. I sanded the case with 12,000 grit wet paper then brushed gold paint into all the detailed grooves. After the paint was dried I repeated the sanding proves and applied a few coats of linseed oil. I'm happy with the results.
    bazas likes this.
  27. D.th.munroe
    D.th.munroe Registered User
    Feb 15, 2018
    464
    167
    Full time clock and watchmaker
    BC Canada
    This is a little late, but this is a very very old recipe to make gold paint out of gold leaf.
    Take gold leaf and mix it in a tablespoon or so of honey until the leaf is fully pulverised,
    add hot water, stir, let it settle, pour off the water, and do that a couple times to wash the gold, then a final rinse in alcohol.
    And then they say to add it to shellac, but really you could use any clear base.
    Dan
    bazas likes this.
  28. bazas
    Dec 3, 2015
    45
    That is an amazing clock. I just love the slate clocks they clean up with great results.
    I believe this is Shell Gold. Instead of honey you can use Gum Arabica. I found a couple of videos on You Tube on how to do this.
  29. Joseph Bautsch
    Dec 9, 2006
    1,113
    125
    Atlanta, GA
    bazas, Paul, really good job on those clocks.
    bazas likes this.
  30. Paul Arsenault
    Jan 21, 2007
    526
    Sales
    Maryland
    Thanks,, I'm still learning and one of the local members Robert Coswell has been a great help as well as all the members of the NWACC
