Skeleton Clock
Discussion in 'Clock Construction' started by WMello, Oct 3, 2017.
  1. Paul Madden
    Paul Madden Registered User
    Apr 24, 2017
    59
    Bienne, Switzerland
    Hi Wagner,
    Thank you for the information on the bench vise. I think its a great idea, and you must get plenty of use out of it. I checked out the link you attached.
    I guess you could adapt any type of suitable vice hardware and add the wood as you said. Then you can really customize it to suit your needs.
    I really appreciate you sharing Wagner.
    Paul.
  2. Jim DuBois
    Jim DuBois Registered User
    NAWCC Member Sponsor
    Jun 14, 2008
    2,753
    528
    Magnolia, TX
    That of course makes sense. I was reading the 8000 rpm and was thinking either I am reading something incorrectly or there is something I don't know and need to learn. I too use 12L14 for 99% of the pinions I cut. It machines nicely and can be case hardened if necessary.
  3. WMello
    WMello Registered User
    Jan 30, 2016
    155
    15
    Herndon, VA
    Lantern Pinions
  4. David S
    David S Registered User
    Dec 18, 2011
    7,190
    245
    Brockville, On Canada
    Wagner the trundles look proud, and I couldn't blow up the image enough to see how they would be retained. On my screen looked like epoxy or something.
    How are they going to be retained, or are they press fit?
    David
  5. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Hi David,
    Press fit (a bit loose) and Loctite.
    The picture was taken just after assembly; waiting the Loctite to cure before machining the ends.
    Wagner
  6. David S
    Dec 18, 2011
    7,190
    245
    Hi Wagner,
    I hope you have your flak jacket on...lots of folks here don't like engineered adhesives or solder. Although if the application is appropriate it works for me.
    David
  7. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Well, I hope they are not too mad at me; I'm just following the plans.
  8. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
  9. David S
    Dec 18, 2011
    7,190
    245
    I was just funnin with you. What type of Loctite did you use? Was it more like an epoxy, rather than the traditional anaerobic stuff?
    David
  10. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Hi David.
    I Know; really don't care much if people get mad at me.
    I use the Magic Green Goo called Loctite 603
    Wagner
  11. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Not happy with the small wheels; the teeth looks fat.
    And fat they are.
    The wheel was cut with the top cutter shown on the picture. The design measurement for the tip is 0.0344
    Considering several possibilities, including witchcraft, turns out the problem is run-out on the CNC spindle.
    I've measured the run-out to be between 0.002" and 0.003". Installing several cutting tools, rotating the collets, and averaging the results.
    The bottom cutter on the picture was cut adding 0.006" to the tool diameter (2 x run-out) on the CAM software; it seems a little too much; looks like 0.005 will be perfect.
    Wagner
  12. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Better
    Paul Madden likes this.
  13. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Some parts
    Escape wheel
  14. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
  15. Paul Madden
    Apr 24, 2017
    59
    Bienne, Switzerland
    Very nice. Thanks for sharing Wagner.
    Paul.
  16. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Motion work
  17. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Fusee, maintaining ratchet and great wheel
  18. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    So far...
  19. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
  20. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Things
    Hello, is there anybody in there ?
    W
    Paul Madden and David S like this.
  21. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    More things
    It moves
  22. Phil Burman
    Phil Burman Registered User
    Mar 8, 2014
    176
    Suffolk England
    Hi Wagner, the clock looks very impressive as does your rate of progress. I am curious about the barrel click and ratchet, there doesn't appear to be a click spring?
    Phil
  23. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Hi Phil, thank you.
    There is no click spring on the barrel ratchet. The barrel arbor is only used to preload the string after assembly, or release the spring for maintenance. It is not used in normal operation.
    The winding is done on the fusee arbor. At the back of the fusee, there is a ratchet, click and click spring for the winding.
    Wagner
  24. Phil Burman
    Mar 8, 2014
    176
    Suffolk England
    If at sometime in the future somebody attempts to wind the clock by mistakenly using the barrel arbor key they could be in for a big surprise.
    Phil
  25. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    154
    deceased
    This is true of all fusee clocks.
  26. Phil Burman
    Mar 8, 2014
    176
    Suffolk England
    Not all:
    It seems to me that skeleton clocks are particularly vulnerable to the casual fiddler. At least with the barrel click on top it will tend to fall back into engagement rather than out, and a spring would give added protection. The fact that many have an unsprung click on the underside of the ratchet doesn't make it any safer.
    Just a thought.
    Phil
  27. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Pendulum components
    SkeletonClock 279.jpg SkeletonClock 280.jpg SkeletonClock 282.jpg SkeletonClock 288.jpg
  28. Allan Wolff
    Allan Wolff Moderator
    Mar 17, 2005
    651
    51
    Tulsa, OK
    Wagner,
    Looks like you are almost complete!! Thanks for sharing your progress.
    All,
    When making your own fusee clock, it is a good idea to make the fusee winding arbor smaller than the barrel arbor so the key will not fit on the barrel and thus avoid winding the wrong one.
    Allan
  29. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    I will have to take better pictures tomorrow
    musicguy likes this.
  30. musicguy
    musicguy Moderator
    Jan 12, 2017
    5,664
    2,745
    New York State
    Your cat looks like it's enjoying watching you build the clock.
    Rob
  31. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Hi musicguy (Maxwell Smart). Yes, the fuzzy guy is very curious.
    Here some entertainment:
    This is the first run. There's still a lot to be made and adjusted.
    The thing is running too fast, the amplitude is too much (aperture angle of the pendulum; is this the amplitude ?), and the escapement action does not look really right. And I may have cut the invar rod too short (shoot-me).
    Wagner
  32. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
  33. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,039
    95
    El Dorado, CA
    Beautiful workmanship, Wagner.
  34. David S
    Dec 18, 2011
    7,190
    245
    I for one second Martin's comments. While I have no desire to make one of these from scratch, I certainly admire the craftsmanship.
    David
  35. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Thank you.
    Your comments are encouragement
    Wagner
  36. sharukh
    sharukh Registered User
    Oct 10, 2011
    353
    14
    Doctor
    Mumbai, India
    It continually amazes me that such beauty can be produced out of sundry pieces of metal and of course tons of hard work. It's awe inspiring.
    Way to go Wagner.
    Sharukh.
  37. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Fusee lock
    Several tries
    Striking
    See it all in action here:
    Wagner
  38. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Power run out at 6 days, 22 hours.
    Will run out of fusee before 8 days.
    May get another turn if catch is turned 180 deg
    Hands
    Almost, but not quite there
    Spring and rate adjusted, running again
  39. David S
    Dec 18, 2011
    7,190
    245
    Wagner, while I have no interest in doing what you do. I am in awe of your craftsmanship. More important you have answered my questions when I would like to know how you have done something.
    Thanks for keeping us informed of your progress.
    David
  40. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Thank you David
  41. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Electric power failure on the morning of day 5.
  42. Paul Madden
    Apr 24, 2017
    59
    Bienne, Switzerland
    The sound of the ratchet is wonderful. It must be extremely satisfying to see all the components assembled, and to see/hear it working for the first time! Thank you very much for sharing Wagner.
    Paul.
  43. Paul Madden
    Apr 24, 2017
    59
    Bienne, Switzerland
  44. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Hi Paul, thank you.
    It is really satisfying seeing it run for the first time.
    It's running for 7 days per winding, barely.
    I will have to act on the fusee stop to get at least 1/2 turn more.
    Now you can see by the post #91 that I have a little problem with the rate jumping.
    I suspect it's caused by lack of lubrication on the main spring; spring loops sticking, dragging and suddenly releasing.
    I've added a little oil (without disassembly) and it is running again. Results on the coming Sunday.
    Wagner
  45. Paul Madden
    Apr 24, 2017
    59
    Bienne, Switzerland
    Hi Wagner, I really appreciate all the photos and videos you have been posting. It's a big undertaking to keep such a photographic record, but it's extremely interesting to watch your progress. I'm sure I'm speaking on behalf of the other members of this forum when I say this. Thanks for taking your time to share your clock project with us, and keep up the great work Wagner!
    Best wishes,
    Paul.
  46. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Still collecting data
    Red is temperature
    Blue is rate. Raw data light blue, dark blue for moving average 60
    Is it normal for a spring driven clock to have such a jumpy rate ?
    Meanwhile,
  47. Phil Burman
    Mar 8, 2014
    176
    Suffolk England
    #97 Phil Burman, Jan 21, 2018
    Based on my limited experience I think the rapid increase in rate followed by a gradual steady loss of rate indicates a spring either binding on itself or on the sidewall of the barrel. If you listen long enough every so often you can hear a sudden release of the spring. I found that this action tends to disappear after a few windings. You might also look into your lubrication of the spring.
    Just some thoughts from a relative beginner.
    Phil
    PS: Possibly take the end plates off the barrel and look for marks on the inside of the end plates.
  48. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Hi Phil, thank you.
    That's what I thought.
  49. Paul Madden
    Apr 24, 2017
    59
    Bienne, Switzerland
  50. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Continue
    Working on it
