Skeleton Clock
Discussion in 'Clock Construction' started by WMello, Oct 3, 2017.
  1. WMello
    WMello Registered User
    Jan 30, 2016
    155
    15
    Herndon, VA
    #1 WMello, Oct 3, 2017
    The start
    With a little help from the nosy fella
  2. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Plates filled, drilled/reamed and tapped
    Beginning of the pillars
  3. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Frame
    The boss is not amused.
  4. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Pillars
  5. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Working on the barrel
    Loctite and pins at the back cover, screws at front.
  6. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    More about the barrel
  7. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    End of the barrel, for now.
  8. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Winding and Maintaining Ratchets
    Fuzzy Butt is back.
  9. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Click spring
  10. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Fusee, beginning
    Parts
    Maintaining ratchet click
    Maintaining ratchet
  11. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    This is a recreation of the original thread, whose images are missing.
    The original will be abandoned, new entries will be posted here.
    Thank you for the 1854 viewers of the original thread.
    Wagner
  12. Allan Wolff
    Allan Wolff Moderator
    Mar 17, 2005
    683
    64
    Tulsa, OK
    Wagner,
    Thank you for going to the trouble of re-posting the missing pictures. I have locked the old thread so we don't have 2 threads going, but didn't want to delete it and lose the responses already there.
    Keep up the good work!
    Allan
  13. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Fusee
    Not happy with first one, making second
    Wagner
  14. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Fusee turning contraption
    Turning radius, with auto-feed
    Cross slide lead-screw removed
    Threading over the radius
    Wagner
  15. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    And a gif
  16. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,059
    105
    El Dorado, CA
    Turning a fusee cone seems to be one of the bravest things one can do where machining parts is concerned.
    I know there were tools specifically made for doing this, but you seem to have taken a more direct approach.
    Would you be willing to share more about what you actually did?
    Not the specifics of feed speed and such... Just the high-level thought and execution for this process.
  17. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Hi MartinM, thank you.
    It works like a lathe taper attachment. The cross slide lead-screw is removed and cross slide gibs are slacked a bit.
    A bar is secured over the lathe bed and a arm is connected between that bar and the cross slide. The spacing of pivots of the arm corresponds to the radius required.
    When in use, the lathe lead screw pulls the carriage (via auto-feed or half-nut for threading) and the arm pulls or pushes the cross slide accordingly.
    I have filmed the operation but the videos are too long and boring. I will edit a little this evening and will have it uploaded by tomorrow (I hope so).
    Wagner
  18. MartinM
    Jun 24, 2011
    3,059
    105
    El Dorado, CA
    Thanks. I think I get what you mean but, in this case, a moving picture would literally be worth a thousand words.
  19. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
  20. tok-tokkie
    tok-tokkie Registered User
    Nov 25, 2010
    318
    Cape Town, South Africa
    I would have been very confused if I was cutting the 'thread' section that the tool was not in contact with the curved surface all the way.
    Thanks for the video - I did not appreciate that the near pivot of the link was fixed in space. Now it is all clear how it works.
  21. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    I tok-tokkie,
    It is a little confusing on the beginning.
    Please note that the cut at the left side of the fusee is shaped like a bowl, and on the right side shaped like a inverted "J".
    The stem of the "J" (or say the right cheek) must be cut first.
    Wagner
  22. MartinM
    Jun 24, 2011
    3,059
    105
    El Dorado, CA
    Thank you so much for that.
    It's all much clearer, now.
  23. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Fusee (II)
  24. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Wheel cutting
  25. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
  26. tok-tokkie
    Nov 25, 2010
    318
    Thanks for the video of making the cutters & then cutting.
    It seems as if the cutting face of the tool in the fly cutter does not lie on the diameter of the fly cutter holder. Is that correct or are my eyes deceiving me?
    I thought the usual procedure is to cut the teeth in a single pass at full depth but with slow feed. Then cut again with a polishing cut. How many down steps did you use & what was the depth of cut for the final polishing cut?
  27. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    I tok-tokkie
    Thank you for the comments.
    You have observed right. The fly cutter bit is held centered on the arbor, as in the figure A
    As opposed to B, it will create a apparent negative back rake, as in C. But I dont know if this is really relevant, as shown in E.
    I was concerned about having just a thin wall of steel behind the cutter, or too short set screws.
    The minimum speed on my machine is 8000 RPM, so the mass and balance of the thing must be kept within reason.
    About the cutting procedure, you are right again, in a traditional manual operation.
    As I am using a homemade router CNC and 4th axis setup, I dont have to turn cranks by hand, so I can deviate a little from tradition.
    By cutting just one DOC at a time and rotating the blank for the next teeth I can see the marking dye gradually go away and don't have to "decide" on a final depth of cut from the very beginning. According to the remaining of the dye I can stop the operation at the end of a rotation and all teeth spaces will be at the same depth. I have been lucky and the calculated depth has worked well for all the wheels so far.
    Also, I have to think about the limitations of my setup. It works better with shallow DOC and faster feeds.
    On the video example:
    Arbor diameter: 3/4"
    Cutter: 1/4" x 1.125" long W1 tool steel
    Hardening/Tempering: 800°C / 290°C (1472°F / 554°F)
    Blank: Brass 260 1/16" thick 2.2137" diameter
    Wheel: 42 DP, 90 teeth
    Cutting: 8000 RPM
    DOC: 0.007" per pass
    Total depth: 0.0728"
    Feed: 5 IPM
    So, 10 passes at DOC 0.007" plus 1 pass at full depth and 0.0028" DOC plus a last spring pass at full depth.
    Please note that most of the parameters are just a educated guess, based on previous experiences.
    Wagner
  28. Phil Burman
    Phil Burman Registered User
    Mar 8, 2014
    177
    Suffolk England
    Hi Wagner. things look to be going really great, some fantastic work. Did you consider cutting the fusee with your CNC mill?
    Phil
  29. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Hi Phil, thank you.
    I've tried. Wrote a g-code for it and did a test run. Used a bull-nose 1/16" end mill, but got too much chatter.
    I guess because both sides of the end mill where rubbing on the walls and my CNC router disguised as mill is not rigid enough for this.
    Wagner
  30. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    My first pinion in steel:
  31. tok-tokkie
    Nov 25, 2010
    318
    Yes diagram E explains it. It means the back relief angle has to be a bit bigger.
    I have been drawing up a set of gears & had planned on making a different style of fly cutter. Now I will probably follow your example.
  32. Phil Burman
    Mar 8, 2014
    177
    Suffolk England
    What I did was to mill a stepped, reducing diameter spiral 2 mm wide using a 6 mm end mill then just ran a 1.5 mm ball nose with two passes to produce a groove for a 1.4 mm bronze cable.
    I used Allans' spreadsheet and the Excel curve fitting function to produce a polynomial equation for the curve and then used this to calculate a table of z position for every turn of the fusee and x axis movement of 2 mm. Not as difficult as it sounds. By using this method you can easily produce a fusee curve with any profile you like.
    Phil
  33. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Hi Phil, tok-tokkie.
    Tok-tokkie, the relief angle used was 10°
    Phil, interesting process and clearly described. Thank you.
    Wagner
  34. tok-tokkie
    Nov 25, 2010
    318
    My thought processes are no longer what they were. After diagram E when the center of the fly cutter is in line with the gear tooth the cutter will be 'overcutting' slightly. The cutting tip follows the red circle and that will take it deeper into the gear material. It is diagram D which shows the full depth that the cutter will cut - move the cutter to the right so it is in the tooth. Sure, you will arrange that the actual cut gives you the tooth width that you want but the profile cut will be marginally different to the profile of the cutter. Again that can be compensated for - in fact it is what I had to do for the gear cutters I was intending to make.
  35. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Hi tok-tokkie, it could well be, I don't know.
    On making a new arbor, the bit could be made to align with the center line.
    In the practical world, there is too many variables; Even cutting the profiles by CNC, they seldom end up exactly as intended, there is the difficulty of aligning the cutter on the center of the blank, there is vibration and deflection, then the profile is changed slightly on hardening (for pinions), again on polishing...
  36. Kim Miller
    Kim Miller Registered User
    Nov 21, 2012
    60
    Hi WMello,
    Great work!!!
    What brand of lathe are you using? I have a Sherline but it seems too small to be turning a fusee.
    Thanks.
    Kim
  37. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Hello Kim,
    Mine is a PM1030 from Precision Matthews
    Wagner
  38. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    By alchemy and fire, steel bites steel
    Hardened W1steel cutter, W1 steel blank
    Wagner
  39. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
  40. John MacArthur
    Feb 13, 2007
    355
    30
    Mello -- This all looks terrific. I wonder what RPM, feedrate, and cut depth you are using, and is that a 1/8" mill? Carbide? Are you just super-glueing the wheels down to an aluminum plate?
    I'm generally pretty cautious, but it looks like you may be running a little faster, even before the time-lapse.
    Thanks,
    John MacArthur
  41. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    #41 WMello, Oct 28, 2017
    Hi John, thank you.
    The wheels are 1/16" thick and just glued to the aluminum base (Loctite Professional Super Glue, the blue bottle). Parts are removed later with heat, or a long bath in acetone.
    The fist part of the video, on the large wheel, shows a roughing cut with a 1/8" end mill (carbide) 0.010" DOC, 15 IPM, 8000 RPM
    The smaller wheel is about 1" diameter and the cutting was done in two steps. Fist a roughing cut 1/16" carbide 2 flute end mill, conventional cut, 0.010" DOC, 15 IPM and a little over 8000 RPM. I've used a spiral lead in move; the bit ramps down to the DOC, then a cleaning round is done enlarging the cut to 0.070"; this widened "tench" prevents the bit to hub the walls.
    Then the final cut with the same 1/16" bit, 0.008" DOC, climb cut, 20 IPM, the same little over 8000 RPM, spiral cut.
    The 8000 RPM is the minimum of my spindle (Bosch router) and the "little over" means the step 2 of the speed dial.
    15 or 20 IPM is a little faster than I normally do too, but It was a brand new end mill, used the first time today and I was feeling lucky...
    I got the end mill from the eBay "drillman1" and they are supposedly by Kyocera.
    Wagner
  42. tok-tokkie
    Nov 25, 2010
    318
    I tried the super glue idea - details came from W.R.Smith book. I probably used too deep a cut because the work came unstuck. Later I saw someone using hot melt glue which worked very well. That is what I am going to try next time. Plus a shallower depth of cut.
  43. John MacArthur
    Feb 13, 2007
    355
    30
    Thanks for that, Wagner. My parameters are approximately the same, except for the feedrate. Maybe I'll try a little faster. I clamp my wheels down at the perimeter to a small jig, and so have plenty of rigidity. I'm using Rhino, CamBam, and Flashcut - what are you using? Sooner or later, I swear, I'll post some pics of my most recent regulator, which is nearly finished.
    John MacArthur
  44. Paul Madden
    Paul Madden Registered User
    Apr 24, 2017
    59
    Bienne, Switzerland
    Hello Wagner,
    I have a question regarding something I observed on your YouTube video titled "ClockMaker Help"
    It appears that the bench top you are using features a built-in wooden vice, that can be used to support large work such as a clock frame.
    Did you build this combination bench top/vice yourself, and if so, would it be possible to post some photographs of it with a description of how you made it?
    It looks extremely useful.
    Best wishes in the meantime,
    Paul.
  45. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Hello Tokie-tokkie, John and Paul,
    Tokie-tollie, sometimes the glue fails here too. To get a good grip, the surfaces must be absolutely clean. I use acetone and if on the lathe, a fresh surface cut. Also the glue fails with heat, so the work must be kept cool.
    John, we will remember the promise about the pictures. I use Autocad, CamBam and Mach3.
    Paul, the workbench was made for woodworking, well before I started with clocks. The top was made with 2x4 glued vertically, it is 3 1/2" thick. The vise is a somewhat standard vise for woodworking, one buys the metal parts and add the wood. Something like this:
    Cabinet Maker's Front Vise | Grizzly Industrial
    Wagner
  46. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Not exactly a success today
  47. Phil Burman
    Mar 8, 2014
    177
    Suffolk England
    I also used glue but found it to unreliable so I made up clamping arrangements for crossing out 5 and 6 spoke wheels, see photo, and a range of clamps for holding wheels while cutting teeth, one of which is included in the photo. Now wheel making is much quicker and risk free.
  48. Jim DuBois
    Jim DuBois Registered User
    Gibbs Literary Award NAWCC Member Sponsor
    Jun 14, 2008
    3,008
    677
    Magnolia, TX
    Maybe I am misreading the process here, but are you cutting steel pinions with a fly cutter running at 8000 rpm? If so I would like to hear more. A long time ago an early clock building fellow by the name of Bill Curtain told me he also fly cut steel pinions at high speed
  49. Phil Burman
    Mar 8, 2014
    177
    Suffolk England
    I think the reference to 8000 rpm is in regard to crossing out wheels with a CNC milling machine using end mills
    Phil
  50. WMello
    Jan 30, 2016
    155
    15
    Herndon, VA
    Hi Phil, Jim,
    The steel pinions where cut at the mill, with a single tooth fly cutter at 400 to 600 RPM.
    And the results are not perfect, as you can see in the picture. The clock plan calls for lantern pinions, but I decided to experiment with steel pinions.
    The little one, with six leaves looks ok and will be used. It was made from free-machining 12L14 carbon steel. It will go on the clock motion work, driving the Hour wheel; as I understand, at this position there is no need for hardening as there is very little force involved.
    The other pinions where cut from W1 tool steel and the results are not so great. There was some chatter, flexing and premature dulling of the tool.
    The machine running at 8000 RPM is the CNC router; I use it to mill the cutters profile, crossing of the wheels and general parts in brass (some on mild steel) with carbide end mills. It is also used to cut wheels teeth.
    Wagner
    PS. Phil, good looking devices there. My jigs normally looks cruder.
