Single Weight Cuckoo Clock
Discussion in 'General Clock Discussions' started by Wayne C. Anderson, Apr 21, 2010.
  1. Wayne C. Anderson
    Wayne C. Anderson Registered User
    Dec 20, 2001
    933
    that is marked (as much as I can read):
    nadler anstalt
    stern germany
    0 jewels unadjusted
    on the movement. Would anyone have any information on this type of clock? Thanks
  2. RJSoftware
    RJSoftware Registered User
    Apr 15, 2005
    8,328
    79
    Loxahatchee, Florida
    Hey Wayne.
    Sorry I can't help much. Pretty sure this is 60-70's German cuckoo from black forrest.
    One thing about these single chirpers, I still can't see how they are suppose to work.
    Somehow a wire grips and then slips or something. Wish someone would explain this in detail.
    RJ
  3. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    156
    deceased
    #3 harold bain, Apr 21, 2010
  4. Scottie-TX
    Scottie-TX Registered User
    Apr 6, 2004
    936
    Mesquite, TX
    Cam timing and wires: That's how they work. A cam with four lobes:
    The cam lifts the left bellow. as it lifts, a wire crosswise to the other bellow begins lifting the right bellow. When the first bellow falls off the cam it chirps followed by a chirp from the other bellow. One cuckoo every quarter.
  5. Chick Curry
    Chick Curry Registered User
    Jan 31, 2001
    225
    school administrator
    Camden, Delaware
    I have serviced some of these types. The trick (it can drive you nuts) is to have the little wire and place it meets the horizontal wire clean and shiny.. When the cam lifts the left and then the right bellows as well to their upper limit a little crooked wire will position itself so that is holding the right bellows in the up position. When the cam drops the left bellows and the bellow is falling and chirping the horizontal wire will 'kick off' the crooked wire which drops the right bellows moments later producing the other chirp. At best it is a very quick coo coo. If you haven't got it right you will just hear coo. Be sure to hold the clock in its normal vertical position so that your adjustments work when it's on the wall again........"it can be done" you will get frustrated at first, but just take your time and don't bend anything very much. Years ago I was the one that was Nuts.
    good luck
    Chick 146736
  6. Wayne C. Anderson
    Dec 20, 2001
    933
    Thanks to all for the information. The one that I was high bidder at the auction ($1.00USD) keeps time and chimes every 15 minutes. The case is very dirty, but a bit of cleaning made it presentable. Still trying to find information about the maker "ANSTALT".
  7. Uhralt
    Uhralt Registered User
    4,809
    560
    In German, "Anstalt" usually refers to a closed hospital for mentally ill patients. It is possible that the clock has been assembled by patients of the "Anstalt".
  8. Kevin W.
    Kevin W. Registered User
    22,386
    345
    Wayne for a buck you did ok i think.
    I have many cuckoo clocks, and i may get a few of the larger ones going, but the smaller novelty type i doubt it.
  9. dholk
    dholk Registered User
    Feb 8, 2007
    104
    Clock Repair, Antiques Dealer
    Fort Walton Beach, FL
    To get one of these buggars working properly unless, of course, you have been thoroughly trained on the particular one requires much patience and ability to figure out complex mechanisms; also a good bit of luck.
  10. johnj
    johnj Registered User
    Dec 20, 2018
    Hi there I have a clock similar to yours, do you know what weight and chain is used on this clock?
  11. shutterbug
    43,207
    1,189
    I think they used the same chain as is standard on the Regula movements in modern times. You can use a thin strip of paper to make impressions from the sprockets, then count links per inch. The weight was not real heavy. Just use a cone weight like that used for the time side of a 30 hour cuckoo. These clocks are not great time keepers, and are fiddly to get to cuckoo. They just cuckoo once at each 15 minutes.
  12. johnj
    Dec 20, 2018
    Thank you for the help I will give it a go.
  13. Andrew Bowker
    Andrew Bowker Registered User
    Jun 3, 2020
    Hi. I’m new to the “world of clocks” and I’m enjoying the whole learning process from wall and mantle clocks to pocket watches.
    But, and it would appear, like a few others, this single weighted cuckoo clock is proving to be my nemesis! The time side is working a treat and keeps good time (ish)
    I now know, looking at the photos above that there are bits Missing from the mechanism. The only original part is the lifter from the four lobed cam to the left bellow. Can somebody possibly sketch or the like what else there should be to raise and, more crucially, drop the right bellow.
    The above picture gave me relief that I didn’t have the only one of these in existence but wasn’t quite clear enough to figure out the mechanics. Best wishes to all
    Andy.
  14. shutterbug
    43,207
    1,189
    Best for us to see what you have. Take a pic of the back side setup for us.
  15. Andrew Bowker
    Jun 3, 2020
    Thanks for your quick reply. This is what I have to play with so far.
    Cheers Andy
  16. Andrew Bowker
    Jun 3, 2020
  17. RJSoftware
    Apr 15, 2005
    8,328
    79
    Believe it or not, this type of cuckoo's bellows is one of the more complex mouse trap operations that there is. I see you have the necessary other parts behind the clock.
    Understanding the simple thing it does helps clear the thought process. All it does is one cuck-coo. The cam lifts BOTH bellows at same time, then drops one and as the first closes the second one drops. Thus both bellows close at different intervals. Creating the two syllable cuck-coo sound.
    A good example video should be available. From what I remember the adjustment is finicky when trying to get both bellows to not fall same time.
  18. TEACLOCKS
    TEACLOCKS Registered User
    Mar 22, 2005
    2,317
    77
    Clock service & repair
    Santa Rosa Calif.
    This is maybe a closer look at one together.
    LOOK very careful & maybe you can figure it out.
  19. Andrew Bowker
    Jun 3, 2020
    Thank for your reply’s advice and help. Teaclocks thanks for the photo. Am I right in thinking that the cuckoo itself is used as a counterweight to the second bellow?
  20. RJSoftware
    Apr 15, 2005
    8,328
    79
    Yes, the bird tilts, reducing the bend angle so the wire can slide past. If that bellow doesnt weigh enough for correctly acting, you can glue a small coin or washer on top to assist.
  21. RJSoftware
    Apr 15, 2005
    8,328
    79
    But when searching this kind of cuckoo I couldn't find term/name. Anyone know?
    I tried terms like "one chirp" and "hour cuckoo" etc. Teaclocks chirps the quarter hour.
  22. Old Rivers
    Old Rivers Registered User
    Oct 4, 2016
    103
    11
    North Texas
    Your photo speaks volumes. That really is ingenious.
    RJ's reference to a "mousetrap" is spot on!
    Bill
  23. shutterbug
    43,207
    1,189
    I have heard them referred to as "windmill cuckoo's" because of the wheel. Andrew - you can see from the picture that teaclocks supplied, that you have the lift happening, but you don't have the crossover wire to raise the right bellows nor the wire that actually provides the shelf for the delayed drop. When the left bellows drops, it knocks the right wire off the shelf ... so you have to have the delay accounted for. Those things were cheaply made and are a challenge for even the pro's to get right.
    We have something in common! My first successful repair was on one of those danged things. If you can get that one right, you are on your way! :D
  24. Andrew Bowker
    Jun 3, 2020
    Wow! A huge thankyou for all your help and advice in such a short time.
    Well with the aid of a few reworked paper clips and soft copper wire I have a “working” cuckoo!
    Things just at the prototype stage to see how it should work to tweak and bend wires I’ll then remove it all and rebuild the final clock up. Thanks for the advice regarding gluing coins to the top. They really helped.
    Once I have the finished project I will post photos and video. Many many thanks again to everybody.
    Stay safe and keep smiling!!
    Andy
  25. Andrew Bowker
    Jun 3, 2020
    As promised photos of the finished. Cuckooing clock. Thanks again for all your invaluable help information advice and encouragement.
    Keep ticking
    Andy
    2FAC5D5D-D35C-44EF-B08A-B5249880F879.jpeg 16EC8DA1-8F10-4AB8-8AA7-70D9962781E4.jpeg image.jpg
  26. Andrew Bowker
    Jun 3, 2020
    Thought you may like to see a few more completed projects.
    The modern (30yrs old) wall clock was a strip and clean of the Westminster chimes. The anniversary clock was a complete strip down clean and rebuild plus a replacement suspension spring.
    The older wall clock was a complete strip down clean and rebuild it had been in a cardboard box in the attic for around 30yrs
    The pocket watch was just a clean.
    The carriage clock was a strip of the case to repair the top glass and reattach the handle after a painting fell on to it.
    The final little alarm clock was a full stop down and rebuild plus repair to the main and alarm spring.
    The mantle clock was a strip clean and rebuild including reattaching the glass door.
    And finally a second anniversary clock in pieces which was cleaned rebuilt and works lovely.
    All great fun.
    AA8EFFE8-7A79-44D4-99AC-D76F39105765.jpeg 95DA84F1-0566-4DCF-932C-746C8BCBF910.jpeg 385FBC9D-1784-463E-B5B8-1E9AEAD285C7.jpeg E1975747-2C0F-49C6-878C-52677FB0B1EC.jpeg 8446D2AF-A444-4542-9C02-F157C0543462.jpeg EB9E08F9-4264-4012-81B8-17739AB01458.jpeg 483775B9-A5D6-47DB-AC50-48F7276ADC7C.jpeg 8FC804E3-29C1-47D7-9032-043715A5BB66.jpeg
  27. JTD
    JTD Registered User
    Sep 27, 2005
    7,501
    486
    It is nice to see your other achievements, but now they are all hidden in a thread dealing with single weight cuckoo clocks.
    It might have been better to start a new thread.
    JTD
  28. Andrew Bowker
    Jun 3, 2020
    Hmmm. Didn’t think of that. Thanks for comment and advice.
  29. JTD
    JTD Registered User
    Sep 27, 2005
    7,501
    486
    A moderator may come along and move it for you if he thinks it wise. But putting so many entirely differing clocks (and even a watch!) in one post also makes that difficult.
    Anyway, you'll know for next time!
    JTD
