(Tagged as IBM because IBM and Simplex clocks are virtually synonymous)
I've had this Simplex synchronous clock for over 10 years, salvaged from a building where it was taken down presumably because the correction didn't work. With Harold Bain and other NAWCC member's help, I was able to revive the correction, specifically thanks to a box of spare parts Harold graciously sent me. It has worked great ever since then, correction and all, with one exception: the movement makes a rattling sound that I just can't seem to find! I don't know if maybe the motor itself is rattling, or if maybe something inside the movement is not quite right. I've attached a video link below, does anyone have thoughts on what might be going on, or maybe you've seen this before?
