Should I oil lantern pinions?
Barrymac
Golden Circle
Sep 8, 2004
152
7
The title says it. I've been oiling pinions for many years except "the book" says don't on 400 day clocks. Now I'm told don't oil any pinions and thereby don't oil the gear teeth. Opinions?
5,528
827
Thanks for your input.
Why is that? It just seems that metal against metal should have some kind of lube. Too much of a dust collector?
If the shape of the wheel teeth is optimal, there should be almost no gliding (creating friction) but a rolling motion. And, you are right, the main reason not to oil is to prevent abrasive dust from sticking. If you have a perfectly dust-free environment, oiling should do no harm.
Barrymac
Golden Circle
Sep 8, 2004
152
7
I've been doing this a long time but this shows you can always learn something new. Thanks so much.
16,900
2,850
One fairly common problem with clocks, is that crud builds up in the gullets of cut pinions and this will eventually stop the train. The fly pinion on a Hermle movement (chime side) has fine teeth and a bad habit of stopping when dust and oil get together. The lower pinions can do the same thing but (on them) you usually only have a power loss, not a stoppage.
Reactions: Old Rivers
John P
Sep 17, 2010
1,201
158
75
There are exceptions....
I don't normally oil them but an old mantle clock movement with a noisy strike train will get a bit of oil.
We have rebuilt many modern grand father clock movements with black poop ground into the pinion leaves.
It must be scraped and dug out with toothpicks before they go into the ultrasonic cleaner.
Hermle, Urgo's, Kieninger, it doesn't matter who made it, the issue is the same. The higher in the train, the more likely it will stop the clock or the chime operation..
Are they oiled when newly assembled? YES Die stamped wheels and their mate/pinions will wear in better with slight lubrication.
If not, then where does the black poop come from? Dust aint black unless it is mixed with oil.
my 2 cents
johnp
175,310
1,533,455
52,673
PeteABC123
1,063
2,972
