Short introduction of my person
Bernhard J.
Jan 10, 2022
78
78
Berlin, Germany
Hello,
I did not find a subforum for introductions and, if I have overlooked such a subforum, I kindy ask a mod to shift it to the appropriate place.
My name is Bernhard, I reside in Germany, and collect pocket watches, specifically from England, and to lesser extent precision clocks. A number of vintage wristwatches has naturally also found their way to me. I like to work on the watches and clocks myself and have aquired the confidence to do this even with complications, like minute repeater.
Using google, I have more or less often found information in the NAWCC forum and have now decided to become NAWCC member and to register in this forum.
Here are a few photos of Englisch pocket watches in my collection, showing the range of my interest.
The first one may be dated about 1700 to 1720.
The next one is a minute repeater hallmarked 1877.
And for the time being an "explorers watch" hallmarked 1903
Cheers, Bernhard
gmorse
13,184
2,543
Hi Bernhard, and welcome to the forum,
Many thanks for posting some of your watches, all highly desirable and in fine condition. I look forward to seeing more of them and hearing some background on them.
As you're an NAWCC member, you have access to the online Bulletin archives and this is one article which may have some interest for you, Paul E. Hackamack's work on the McCabe family.
Reactions: Bernhard J.
musicguy
Jan 12, 2017
8,635
5,171
New York State
I would like to add my welcome to the NAWCC Forum as well.
Rob
gmorse
13,184
2,543
Hi Bernhard,
Hmm, one of Mr. Bonniksen's fine karrusel escapements, but otherwise anonymous.
Bernhard J.
Jan 10, 2022
78
78
Berlin, Germany
Hi Graham,
Well, the inner lid is engraved, but this might be an owner just as well as the "maker" (or retailer). "Campbell" is a quite common name.
SKennedy
Jan 5, 2017
281
173
Very nice watches. Centre seconds Karrusell is rarer than the 'normal' sub second versions I think. Do you know what duration the carriage rotates in? Off the top of my head I think these are 34 minute? Does the button on the case band start/stop the whole watch as per the typical English centre seconds 'chrongraph' of the time? If so I wonder what it acts on as these normally push something against the escapement but I'd imagine it would have to act agains the fourth wheel arbor on the dial side of the plate.
Allan C. Purcell
Feb 9, 2013
3,208
1,325
Germany
Güten tag, Bernard. Nice collection you have there, you must have started quite a few years ago. Tell me, are you a member of the DGC. I too live in Germany, but some four to five hours away from Berlin. Good luck with your search through the Forums.
Allan.
Bernhard J.
Jan 10, 2022
78
78
Berlin, Germany
Off the top of my head I think these are 34 minute? Does the button on the case band start/stop the whole watch as per the typical English centre seconds 'chronograph' of the time?
Correct.
And here is a more common 52 minute carousel, hallmarked 1903. I recall that there also were carousels with about 7 minutes, but never yet saw one.
Cheers, Bernhard
Bernhard J.
Jan 10, 2022
78
78
Berlin, Germany
Allan.
Hi Allan,
I indeed collect since quite a while, almost 4 decades. Somewhat more expensive watches became available to me about 3 decades ago. No, I am not member of the DGC.
Well, 4 hours is just around the corner (in US terms), so I would be glad to meet you by by occasion, just give me a notice if you happen to be around Berlin.
Cheers, Bernhard
Bernhard J.
Jan 10, 2022
78
78
Berlin, Germany
Hi Graham,
This article is indeed a great read and I am happy to note that the findings about my watch are nicely consistent with this research work. Accordingly, my watch is very late, quite near to the latest one known (#8718 versus #8946), and perhaps even the latest known minute repeater.
Cheers, Bernhard
Benjamin E.
Sep 7, 2015
77
25
Correct.
Cheers, Bernhard
View attachment 689502 View attachment 689503
Are the 7 minute variants proper karrusels or could you be thinking of the Robert North 6 minute tourbillon which looks quite similar to the karrusel?
Either way, welcome!
SKennedy
Jan 5, 2017
281
173
The BM has a centre seconds specimen which does rotate in 34 minutes and there's a picture of the brake mechanism under the dial.
Thanks Graham. I've not had one of these types apart so nice to see the under dial details. It sort of has three fourth wheels, the one in the centre of the watch, the one that drives below the karrusel which is the one the stop arm acts against. And then on the other end of that arbor is the wheel which actually drives the escape inside the carriage.
Bernhard, there's also a very rare 42 minute 'proper' chronograph version with running sub seconds and centre second start/stop/reset hand.
Seth.
Bernhard J.
Jan 10, 2022
78
78
Berlin, Germany
Well, this "Centre Seconds Chronograph" feature actually was imho not intended to be used as chronograph for obvious reasons. It served for setting the seconds hand for the exact time. The escapement was halted with the seconds hand at 12, the other hands set as needed, and the escapement released as soon as the reference seconds hand passed the 12. At least I believe so, this makes a lot more sense than a chronograph loosing the time upon use of the chronograph function.
Bernhard J.
Jan 10, 2022
78
78
Berlin, Germany
Hi Seth,
I would love to learn more about that, I never heard or read of that. Do you perhaps have a source?
Cheers, Bernhard
gmorse
13,184
2,543
Hi Bernhard,
This is no different from the way all balance brakes worked on 19th century English watches, and that's how they were meant to be used.
Jerry Treiman
Golden Circle
Aug 25, 2000
6,982
3,621
Los Angeles, CA
Bernhard - Welcome to our community. I am delighted to see how you have enthusiastically jumped into the discussions and brought your own knowledge and experience to the group. I participate in both the European and American forums and look forward to your contributions.
Tom McIntyre
Technical Admin
NAWCC Star Fellow
NAWCC Ruby Member
Aug 24, 2000
84,469
2,209
85
Boston
awco.org
I am happy to have you join us. I have similar interests, but have found it necessary to reduce some of my English collection to make room from a few watches from the McIntyre Watch Co.
I have also kept most of my Barraud collection with a couple of Karrussels AWCo Web and AWCo Web
I also have a nice Bonniksen signed example, but I cannot find the pictures just now.
Tom McIntyre
Technical Admin
NAWCC Star Fellow
NAWCC Ruby Member
Aug 24, 2000
84,469
2,209
85
Boston
awco.org
I took a movie of the watch running and upoaded it to the gallery. I think I can post it here but I have not done that very often...
It was not that difficult, but there is a fairly long delay while it is processed. There is a limit on the acceptable size of the movie.
I think this watch may have been reported lost at sea a bit over 100 years ago. That might have been why I have not shown it before. I may be able to find its record of purchase, etc.
zacandy
Nov 6, 2019
37
37
London
Welcome bernard I am intrigued to see your Finer and Nowland watch
All the best Andrew
171,040
1,493,333
50,086
Johnfn70
2,967
