Shop Made Ultrasonic Cleaner
Cuckoojohnboy
Feb 28, 2011
105
Has anyone ever made an ultrasonic parts cleaner? I seem to remember reading about one a while ago but could not find it when I did a search.
Thanks!
cuckoojohnboy
R&A
Oct 21, 2008
4,212
108
Yeah I saw one on here where a guy made one from a foot massage machine. But I don't know about making one. I guess a guy would try. Seeings that they are so expensive....
H/C
Mike Phelan
Dec 17, 2003
10,689
247
West Yorkshire, England
You'd have to get the transducers which will be rather expensive. The rest of the electronics is fairly and crude simple to make apart from the wound components. I've repaired a couple of them that had been scrapped - they were both L&R.
I gave one away to a friend and sold the other as I have no need for one.
48,530
2,533
I'm guessing that it would be like trying to build a car from parts. The cost is actually more than buying it outright.
Mike Phelan
Dec 17, 2003
10,689
247
It would indeed be, even without counting the labour. Small passive components are cheap, but the problems would be transducer costs and designing the wound components. Here are circuit diagrams of the two I repaired:
lifeisgud71
Jul 30, 2008
34
Nebraska
Hello Cuckoojohnboy,
Here is a photo of mine. Does not clean real well, but makes my feet feel better!!
The only expensive part was the stainless pot!!
48,530
2,533
Cute idea - but not everyone is going to have a foot massager lying around, so you have to add that expense into your idea too :)
13,666
85
Hi
Most foot massagers don't drive 50-200watts of 32KHz.
I was just looking at some specs for these transducers.
I see one that is for a 60 watt unit. It is rated a 20 ohms
for resonance. That would be a voltage of 1.7 volts and
34 amps.
It looks like to make one would mostly be a transformer
with enough power and low ohms output.
I suspect such a supply could be made from a scrap
computer power supply. One rated at 300w would most
likely have a low enough resistance secondary to drive
2 of these transducers in series.
One would need to modify the circuit to work as a resonance
feedback oscillator, rather than a regular power supply.
Anyway, it sounds like an interesting project.
Dwight
Thyme
Banned
Sep 18, 2006
3,948
metro NY area
Don't confuse a true ultrasonic cleaner with a vibrating mechanism. :eek: I'm smiling because I have a used unit (that I picked up somewhere over the years) that looks just like a conventional ultrasonic cleaner. But when I looked inside I found that there are no transducers, only a vibrator assembly. In effect, it's a fake. Wanna buy it?
Just because something goes 'buzz' doesn't mean it is an ultrasound unit.
13,666
85
Hi
I was looking at ebay and there are transducer/driver for 60W that you can get
for $70usd. You just need a bucket to connect it to.
I see transducers for around $30-$40 so the $70 looks like a reasonable deal.
Kevin W.
23,443
644
64
Where are the transducers made. I had one made by a company i think it said they were made off shore. No idea really of the maker.
Randy Johnson
Mar 30, 2005
770
Gadsden, AL
H/C
1 used foot massager from the thrift store... $2.50
1 used plastic pan... 79-cents
1 pretty darn good parts cleaner... priceless! :whistle:
It even has a heater! And after a year using "Historic Timekeepers" I'd put it up against models costing twice as much! :rolleyes: - Anonymous
Thyme
Banned
Sep 18, 2006
3,948
metro NY area
Some folks think vibrators are fun. They're good for a cheap buzz... :cyclops:
Len Lataille
Aug 31, 2002
880
I doubt that the foot massager has much to do with the cleaning, other than keeping parts separated so the cleaner can get to them.
Shaking the plastic pan once in a while would so the same, not that the foot massage is a bad idea.
What's doing the cleaning is the heated Historic Timekeepers. I find HT to be a great, almost odor free cleaner that works especially well when it's heated. Same applies to DEOX-007.
Water based cleaners work better when heated. Common sense, as clocks are usually oil and grease covered as well as dirty, which is more easily removed with any heated cleaner that is mostly soap.
Mike Phelan
Dec 17, 2003
10,689
247
Garry
Ah, but with respect Garry, that's not actually "making" it! There again, probably a pondism as when you say you "I've made a clock", we say "I made a clock case and put a movement in it". :)
Thyme
Banned
Sep 18, 2006
3,948
metro NY area
Mike, isn't that a description of what Anglo-American clocks are? o:)
173,587
1,515,831
51,828
Appointible
1,062
2,969
