Shaving Dial Size?
Streetsnake
Feb 28, 2021
76
42
Is it possible to successfully decrease the size of a dial? I have a Lemania 105 that has a dial of 29mm. I found an appropriate replacement but it's dial size is 31mm. There is a significant border around the 31mm dial that could be removed to decrease the size. Could this be done on a metal lathe? Does anyone do this kind of work?
karlmansson
Apr 20, 2013
2,753
172
Linköping, Sweden
Turning the dial down from 31 to 29mm would be a walk in the park provided you have a way to mount it centered on a wax chuck. If the dial will fit you watch is probably the greater issue. You need to make sure that dial feet are in the right place and that any potential holes in the dials line up with any arbors poking through. Dials are often made caliber specific.
Regards
Karl
Streetsnake
Feb 28, 2021
76
42
Regards
Karl
Hi Sir. Both dials I am looking at are virtually identical to the one I have now...just in much better condition. Now I think about it, my movement is a Lemania 1270 and the one I’m looking at is a 1275. where Would I look to determine if the feet are in the same spot? Any idea?
karlmansson
Apr 20, 2013
2,753
172
Linköping, Sweden
Roland Ranfft's movement database has the most information on vintage movements that I know of but I can't remember it having this data on there. On the other hand, according to the information there, the 1270 is the same movement as the 1275 only 1275 has shock protection in the escapement. bidfun-db Archive: Watch Movements: Lemania 1275
Bear in mind that the "significant border" could be the seat area for case and crystal and that removing the border could mean that you would be obscuring the periphery of the dial when it is finally in the case. A larger dial would likely mean a larger case. Possibly a case ring around the movement. Do you have photos of the dials in question? Do you have physical access to both?
K
165,345
1,439,128
86,159
Clockjoyner
2,873
