Shatz Royal Mariner case...
Discussion in 'Clock Case Restoration and Repair' started by madmax9, Feb 9, 2012.
  1. madmax9
    madmax9 New Member
    Feb 9, 2012
    I write from Italy, thank you for your hospitality, I bought a Schatz Royal Mariner fully functional and in very good condition, I tried to clean the case as I believe that it was in solid and full brass but I noticed that the edge of metal around the glass has lost the yellow and appeared a silver color, what do you suggest, can I remake a brass treatment to report it as it was? And I would like to know if theese watches were all in lacquered metal or some of them in solid/full brass?
    thanks for your time,
    Max
  2. Burkhard Rasch
    Jun 1, 2007
    4,077
    10
    General-and trauma surgeon
    Twistringen
    Hi.Max and wellcome to this message board! Schatz ship bell clocks as far as I know allways came in spun brass cases,never heard of any lower metall plated to replace brass.If You want to be sure try wether the case material attracts a magnet:If yes,it´s steel plated,if not I´d bet it is solid brass.Some makers laquered their brass cases with a lightly colored laquer to give the brass a deeper,golden shine.Maybe You polished off that laquer and the underlying bright brass makes the impression of another material.You then have the choice of leaving it as is or stripping off the laquer and relaquering it.HTH
    Burkhard
  3. Uhralt
    Uhralt Registered User
    586
    According to my own painful experience the case of the Schatz Royal Mariner is massive brass, but the bezel that holds the thick glass is NOT. It is a cast bezel made from a gray-silverish metal with a thin brass overlay that can be easily be polished-off. The bezel is not magnetic and can therefore easily misinterpreted as brass.
    When I had polished-off the brass from the bezel of my Royal Mariner I used some metal-containing brass-colored paint to touch it up. It looks not too bad but purists might prefer to leave it as it is.
  4. Burkhard Rasch
    Jun 1, 2007
    4,077
    10
    Twistringen
    ouch,didn´t know that!Thanks for the advice,learned something new...(like allmost every day)
    Burkhard
  5. enfunk
    enfunk Registered User
    Jan 16, 2010
    Hello Uhralt,
    I am now where you were a year ago... my Schatz Royal Mariner bezel was pitted and very "pale." Thinking it was a poor lacquer application, I began to gently polish and found the same thing you did: base metal is silver, non-ferrous. I am committed now - could you please share the paint product and technique you used to make it look more like brass?
    Thanks in advance,
    Erik
  6. Rick_D
    Rick_D Registered User
    Feb 6, 2010
    68
    Add my name to the club. My Royal Mariner now has a silver bezel but I've grown to appreciate the two-tone effect.
    Rick
  7. dAz57
    dAz57 Registered User
    Dec 7, 2011
    1,882
    7
    watchmaker
    sydney Australia
    #7 dAz57, Apr 2, 2013
    over the years I have only ever seen one maybe two royal mariners with solid brass bezels, this out of hundreds I have serviced and checked in the last 40 years, the bezel is zinc casting brass plated, the case is thin brass and the backs are steel, you would think for the money they charge for these things you would get a solid brass bezel.
    none of the plating shops around here will touch them, so the only way I found is to clean the bezel smooth and gold paint it, I just got one in for a service, that I did a service on 20years ago, the paint on the bezel still looks fine.
    I clean the bezel, use a primer undercoat, then a metallic paint like rub n buff, this type of paint can be lightly rubbed after it has dried and will take on a soft metallic shine, you can use a combination of oxidised gold and a brighter gold or brass to give an aged look, what I really don't like is the cheap pale gold sprays, makes it look really cheap, be better to paint the case black in that case :)
  8. Uhralt
    586
    I used the same technique as dAz57. It is important to use a paint that contains real metal particles and to try to match the color of the brass as well as possible. When in doubt, go darker rather than brighter than the brass. The brass will darken over time, unless you put a layer of clear laquer over it. In the US, Michaels carries a variety of metal paints that are suitable. RubnBuff works well.
Similar Threads - Shatz Royal Mariner Forum Date
CLERKE, LATE | C.C. Webb | Royal Exchange | London -- Shelf Bracket Clock Clock Case Restoration and Repair Jul 1, 2017
Conservation of a fire damaged Ansonia Royal Bonn clock Clock Case Restoration and Repair Aug 9, 2016
Schatz Royal Mariner Clock Bezel Issue Clock Case Restoration and Repair Oct 16, 2015
Schatz Royal Mariner clock case - multiple cracks Clock Case Restoration and Repair Mar 8, 2015
cracked clock case of a Schatz Royal Mariner Clock Case Restoration and Repair Jan 16, 2012
