Max Phillips
I just wanted to post here about my recent experience with the 2" 3 jaw lathe chuck sold by Shars. I had been in pretty bad need of a jaw chuck for my little 8mm lathe, and got the Shars one for Christmas. They only sell them with either MT1 or MT2 shanks, but they can be removed and the chucks themselves have threaded backs. Mine had M14 threads. I removed the MT1 shank from mine, and made my own shank to fit my spindle. I turned the shank between centers on my larger bench lathe, and single pointed the threads at either end to get a really nice fit to both the drawbar and the chuck. By trial, I achieved a better fit to the spindle taper than most of the other collets and shanks I have purchased in the past. I trued up the mounting face for the chuck, and the chuck register, on the 8mm lathe itself, to ensure the greatest result possible. I knew I could make an accurate shank adapter, but it was completely unknown to me what sort of error the body and jaws of the chuck itself would introduce. These are all made in China so I wasn't getting my hopes up. I thought that, if I was lucky, the body of the chuck would be acceptably made but perhaps the jaws would need truing up. I chucked a test bar (a length of 1/8" ground round HSS) with a little over 2" sticking out from the chuck. I used a 0.0001" Starett Last Word test indicator to check the runout up close to the chuck, and then 2" away from the chuck. The runout was identical in both places, and was less than 0.0005". I was pretty blown away by that. Of course, I doubt that would be repeatable at different diameters - this is a self centering chuck after all. I'm pretty pleased with this chuck. Note that I disassembled, deburred, cleaned, and oiled the chuck prior to fitting it to my lathe.
These chucks cost $74 (U.S.), and if mine is at all representative then that's a real bargain. One thing I cannot attest to is the accuracy of the MT1 adapter it came with. I don't have anything with an MT1 spindle.
