Sharing recent art deco addition
Discussion in '400-Day & Atmos' started by mjstewart, Jun 15, 2019.
  1. mjstewart
    mjstewart Registered User
    Feb 20, 2016
    35
    Trying to share a few of my recent additions. I believe this to be JuF in the 1927-1934 range owing to the chrome plating and double elephant logo. Plate number 1260 variant?
    etmb61, victor miranda and PatH like this.
  2. etmb61
    etmb61 Registered User
    Oct 25, 2010
    2,462
    164
    Retired Avionics Technician
    Mascoutah, IL
    Beautiful condition. I have no deco clocks in my collection (yet). I like the styles, but most I've seen were in poor shape.
    Plate 1595.
    The suspension bracket should be mounted between the plates with the screw heads visible from the back. It seems to me it would be more difficult to assemble with the screws between the plates, but it happens.
    Eric
  3. tracerjack
    tracerjack Registered User
    Jun 6, 2016
    1,063
    110
    Female
    Lodi, CA
    Love the pendulum and the chrome. My favorite style. Wonder if someone put the bracket on when movement was disassembled and didn’t notice they’d flipped the plate. Then after assembly, didn’t want to take it apart to fix it and left it. Anyway, it’s a beautiful clock.
  4. rmarkowitz1_cee4a1
    Nov 26, 2009
    5,052
    824
  5. mjstewart
    Feb 20, 2016
    35
    Thanks, I was so excited that it started running after putting it in beat that this detail escaped me.
  6. mjstewart
    Feb 20, 2016
    35
    I like this Rhombic theme very much. thanks for sharing.
  7. clksmyhobby
    clksmyhobby Registered User
    Jan 29, 2011
    56
    Retired electronics/aviation technician
    Central Florida
    I found found its twin at a thrift store in south central Florida a couple of weeks ago. It has a plain rear plate - no logo or stamped text at all. It was in pretty sorry shape (lots of scratches and mangled eccentric slot) but complete with what appears to be the original dome. It is now cleaned, lubed and running with about 270 degrees rotation and good over swing. Strange thing though: the minute hand hits against the dome at both the :15 and :45 positions. Gave it a little curl on the end and all is well. This is my second chromed clock, the other is a K&O, plate 1367, with diamond-shaped face plate - good condition except one small crack in the base plate. I like the chrome and art deco look.
  8. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    3,572
    133
    Aerospace Engineer (Ret.)
    San Antonio, TX
    clksmyhobby -
    It would be nice to see pictures of your chromed clock!
    Kurt
  9. clksmyhobby
    Jan 29, 2011
    56
    Central Florida
    In work after I clear a camera malfunction.
  10. Kevin W.
    Kevin W. Registered User
    22,349
    337
    Great looking 400 day clock. Very nice find.
  11. clksmyhobby
    Jan 29, 2011
    56
    Central Florida
    Some quick snaps. I need to read my posts - back plate of Juf has no logo but does have JAHRESUHRENFABRIK G.M.B.H GERMANY. Face is poor shape and bottom block was missing (temp installed for check out).
    Juf back.JPG JuF front.JPG Juf Side.JPG KO chrome front.JPG KO chrome side.JPG
    Wayne A likes this.
  12. KurtinSA
    Nov 24, 2014
    3,572
    133
    San Antonio, TX
    Nice...those square pendulum weights and square columns really help to catch and scatter the light.
    Kurt
  13. clksmyhobby
    Jan 29, 2011
    56
    Central Florida
    You're right. Like a bunch of mirrors in motion.
    for mjstewart: The vertical columns on my clock were cracked from over tightened screws. I put some JB Weld epoxy inside and that seems to work. I'm curious to know if yours had the same defect.
  14. John Hubby
    John Hubby Senior Administrator Emeritus
    Sep 7, 2000
    12,276
    216
    The Woodlands, TX
    #14 John Hubby, Oct 14, 2019
    clksmyhobby, your clock with the blank plate would have been made between 1932 and 1939 based on my extensive database of JUF clocks. This particular dial design seems to have only appeared in the late 1920s and then continued to beginning of WW2.
    My data also show that your octagonal dial clock stamped with JAHRESUHRENFABRIK G.m.b.H. GERMANY was made between 1928 and 1931. I've not found any logo stamps at all on clocks made from 1932-1939.
  15. clksmyhobby
    Jan 29, 2011
    56
    Central Florida
    Thank you, John. My first post was in error about the totally blank rear plate. I meant to say it had no logo, only the stamped JAHRESUHRENFABRIK G.m.b.H. GERMANY. Interesting clock design that caught my attention for purchase primarily because of its chrome finish.
  16. Wimalleman
    Wimalleman Registered User
    Oct 31, 2011
    Haarlemmermeer Netherlands
    Just noticed that the bracket is mounted outside the backplate with the adition of two "spacerrings" between it. Just like mine example, see pictures.
    20170929_122259 (Small).jpg 20170930_171117 (Small).jpg 20170929_122259.jpg 20170930_171117.jpg
  17. KurtinSA
    Nov 24, 2014
    3,572
    133
    San Antonio, TX
    Welcome to the message board, Wimalleman! Does the clock run OK as-is or will you be remounting the bracket?
    Kurt
  18. fixoclock
    fixoclock Registered User
    Aug 29, 2000
    138
    This clock is a beautiful rendition of chrome in motion and deserves to have a glass dome with a mirrored back so as to reflect the light even more than just the cubes. Chrome deco 1.jpg
    The dome has been silvered on 1/3 of the outside then coated with a grey protective material.
    The reflection of the pendulum in the curved mirror is mesmerizing ! Silvered dome2.jpg
    The mirroring was done at a commercial mirror making company.
    Keith Conklin likes this.
  19. Wimalleman
    Oct 31, 2011
    Hy Kurt, the clock does run ok, it seems that this should be the richt position.
  20. John Hubby
    Sep 7, 2000
    12,276
    216
    The Woodlands, TX
    MJ, Eric's plate information is correct. This plate was made from March 1927, the month after August Schatz Sr. died, until mid-1931.
    Wimalleman my welcome also to the Message Board!! Thanks for posting your clock, I'm surprised that with the upper suspension bracket positioned as far to the back as it is, the pendulum does not touch the glass dome at the very back? The factory position is with the bracket inside the back plate as Eric has noted.
