• Upcoming updates
Severe wear, Urgos UW-03, 9 tube.
18,255
3,653
Bad news when you see this!
This is what an 18# weight can do on a modern clock after a 35 year run.
The front winding arbor holes are worn much more than the back ones but the stop-works cogs are in the way for a photo at this time. All 6 are bad.
On a brighter note, the rest of the trains look pretty good. Willie X
18,255
3,653
I'm trying to put a name to a condition like this. My uncle used to say "wore slap out" and I've heard the word "sloppy". I think I might use the word "floppy". Willie X
Reactions: JimmyOz
JimmyOz
Feb 21, 2008
1,372
474
67
Gold Coast Qld
It looks like the bushing has been Orbiting the plate, I wounder how long it took for one rotation?
Peter John
Sep 4, 2018
489
252
Scottsdale, Arizona
Willie, weren’t those movements made late ‘80s early ‘90s? I remember selling clocks with them. They were supposed to run 14 days before needing to be wound. The wear situation was catastrophic and Urgos quickly discontinued them. Peter
18,255
3,653
I think this one goes back to about 1975?
8-Day, AFAIK. Willie X
Mike Mall
Oct 27, 2021
535
200
A southern technical term fits, that I learned while working in Florida.
"Wallered out"
wallered; verb
Term used in maintenance fields to discuss wear that causes a circular fitting to lose dimensionality, often related to vibration or off-center repetitive motion.
The mount for that bolt has been wallered out and will need to be replaced.
Etymology: Southern North-American Slang, mispronunciation of past tense to wallow
18,255
3,653
You may be thinking of the infamous
UW-66. It had light weights and thin plates. I think it was there last new model? It did indeed have some wear problems. I have a photo here somewhere. This one did loose mesh with the 2nd wheel pinion!
Take care, Willie X
J. A. Olson
Dec 21, 2006
5,109
826
WI
When Urgos tried adapting their chainwind UW32 movement to cable drive, the results were disastrous. I think the cable driven UW32 came out during the 1980's when Urgos was facing the end and their remaining clients wanted to get fancy. One of those things that looked like a neat idea on paper and didn't hold up in practice.
Jauch KG tried a similar movement during the late 1970's and surviving examples are scarce. Herschede was a known user of these movements.
49,693
3,032
I think it just needs more weight, Willie! :D
Reactions: Mike Mall
Mike Mall
Oct 27, 2021
535
200
You did a great job of capturing the debris field below the pivot, in your photo.
18,255
3,653
I was wondering if there was a good name for that ... "Debris field" does have a good ring to it. Willie X
18,255
3,653
Here is the worst "wallowed out" place (C1F) before and after. Those file marks were left from filing away the 'banana peeled' edges of the old hole! Willie X
Mike Mall
Oct 27, 2021
535
200
Bronze? Doesn't look like it - but I know that's the latest fashion for lower wheels now.
Mike Mall
Oct 27, 2021
535
200
If this were my personal movement - (time and money not a consideration) - I would have called Mark to fit up some Butterbearings.
This would be a great application. So far all the ones I've installed are sill running great.
J. A. Olson
Dec 21, 2006
5,109
826
WI
AFAIK = keyboard shorthand for As Far As I Know.
Abbeyclock has a gallery of photos including a view inside the movement.
It's an outstanding movement but not for the reasons one would hope for.
180,077
1,570,911
54,367
shaimerej
911
3,090
