Klossee said:IMHO the simplest way is to use the simpler Westminster tune. The first quarter hour with the four descending notes. However, also remember, the chime tubes have to be hung i the correct order.
Tom
“Sometimes you really don’t know if your being rewarded or punished”
stewart said:The arrow indicates the drums rotation. Is this correct for Westminster chime?
Had to post again. For some reason I could not edit above, something about time limit.
Thanks Stewart
Should not be a problem as the entire barrel is always used twice on the hour: 4/4 + 1/4 is the same as 1/2 + 3/4.shutterbug said:A reminder - the 1/4 hour chime is replicated at the end of the 3/4 chime, so be sure you are in the right place when you tighten it up![]()
I have no reason to doubt you, but am having a hard time wrapping my mind around thatShould not be a problem as the entire barrel is always used twice on the hour: 4/4 + 1/4 is the same as 1/2 + 3/4.
The critical final adjustment is to see that the train locks immediately after the last blow.
shutterbug said:It would seem (talking Westminster here), that you would want the 1/2 hour followed by the 1/4 hour to get the 3/4 chime (No!) - that part I can make work in my mind. But you'd need the 1/2 hour to go twice (and that would not be "pure" Westminster either) for the hour sequence. (No - it is the half-hour plus the first 8 notes of the 3/4) So you'll have to explain it a bit more for me. I've never really looked at the barrel closely, assuming that it was a once around each hour arrangement.
Mike said:Bah - spotted an error - sorry, folks:
o---
-o--
--o-
---o
--o-
o---
-o--
---o
--o-
-o--
o---
--o-
o---
--o-
-o--
---o
This one should be:
[colour=red]---o
-o--
o---
--o-[/colour]
