Setting warn wheel and chime strike cam on Hermle 1161
Dan Volocyk
Oct 5, 2010
Hello, I have a Hermle 1161 movement that had a broken warn wheel pin that I replaced. I didn't take a picture so I wasn't sure where to position the pin when I replaced the wheel. I had problems with chiming and have since loosened the chime locking plate too. I took a picture of the movement so you can see where things are at now. I moved it through each position and have it stopped just past the hour. You can see that one of the hammers is up in the picture. The chime locking plate pin is just past the longest lobe on the plate. I think this is the hour position. Can you tell me if the the chime locking plate is position correctly or what do you suggest I do? Thanks!
Mike Phelan
Dec 17, 2003
10,340
130
West Yorkshire, England
I didn't take a picture so I wasn't sure where to position the pin when I replaced the wheel. .... I took a picture of the movement
:confused::confused:
Cannot see a picture.
What is "chime strike cam"?
Is it the striking warning or the chiming one?
Whichever one it is, is the said pin used for locking as well. In that case, the warning run cannot be changed.
The longest lobe on the chiming count wheel (locking plate) is for the hour. To position it, remove it and allow the chiming train to run and lock, then replace the CW with its detent centrally in the notch.
You'll probably need to re-time the chiming pin barrel (to 1/4 or 3/4) if a hammer is up in the air.
47,597
2,226
If we're talking about the chime, then as Mike said. Make sure you're on the Westminster selection if it has more than one tune ... and when you put the wheel back on, put it at the 3/4 hour position. Then loosen the chime ratio wheel on the back and turn the chime drum until you see the four note scale (in order unless you have several chime hammers) fall. Tighten the wheel back down and test it. The train has to lock when the last hammer falls. You don't want any hammer lift during warn.
Dan Volocyk
Oct 5, 2010
Thanks for your help. Is there a descriptive picture of this movement anywhere here so I know what the parts are called?
If I were to buy a replacment movement, would it come ready to run or would I have to do this type of setup work first? I suppose that all depends on how it arrives. Are they generally ready to go?
MARK A. BUTTERWORTH
NAWCC Life Member
Jul 4, 2009
2,516
170
Muscatine, Iowa 52761
Replacement movements all come ready to go. For pricing contact us at 563.263.6759 or butterworth@butterworthclocks.com
47,597
2,226
at the top of the forum, there's a 'sticky' that has part names with pictures to help you find what parts are being discussed :)
168,981
1,474,535
48,688
jade1jerry
2,960
