Setting strike on a 19'th century Seth Thomas
Joecephus
Mar 26, 2021
54
I recently purchased a Seth Thomas weight driven clock which I believe was made in 1884. Question- what is the proper way to set the strike on this clock? It is 4 hours off. For example, it strikes noon at 4. Thanks!
16,556
2,630
It probably has/had a thin wire hanging down behind the dial, left of center. A slight tug, or upward push, will advance the strike one hour. Once the strike agrees with the hour hand, you would set the clock forward to time, allowing the strike to finish at each hour.
There are many variations, a good photo of the movement would allow for more specific instructions, if the above general instructions don't work.
Joecephus
Mar 26, 2021
54
Yes, there is a wire just to the left. I'll try that. Do you pull the wire anytime, or as the clock is striking? Thanks for the info!
Bruce Barnes
Mar 20, 2004
2,023
66
move the hour hand to correspond with the striking hour...........then stop the clock and restart at the appointed hour, e.g., strikes 2 at 6 stop and restart at 2 the next day.
Bruce #3
16,556
2,630
There would be no reason to move the wire while the clock is striking ...
When you move the trip wire the strike will advance one hour, as already mentioned.
Bruce Barnes
Mar 20, 2004
2,023
66
Willie X, my solution is if you don't have the trip wire,both ways will work.
Mike Mall
Oct 27, 2021
247
77
The instructions are on the label, bottom of this section.
Mike Mall
Oct 27, 2021
247
77
Yes, the instructions are there. It mentions using the wire to adjust the strike. But doesn't tell you how to do it.
Follow Willie's instructions - by raising the wire as stated on the label.
In other words ... raise the wire then let it go, this should start the strike - then wait until it stops striking.
Repeat this until the strikes match the hour hand.
Mike Mall
Oct 27, 2021
247
77
That's great!
By the way I forgot to mention something that I should have - in case it happens again.
When the clock is between about 10 minutes before, until shortly after the hour, that wire won't work. The clock is getting ready to strike on it's own, and it's not going to strike for you.
174,396
1,523,873
52,192
danarog
1,063
2,971
Last page
