Seth Thomas Westminster Electric Clocks
Discussion in 'Electric Horology' started by JoyF, May 18, 2017.
  1. JoyF
    JoyF Registered User
    Jun 4, 2013
    212
    I've acquired two Seth Thomas Westminster Chime electric clocks. Instructions read you are supposed to wind two arbors on the movement. Where are these arbors located? Can't seem to find them. Thanks.[​IMG][​IMG]
  2. THTanner
    THTanner Registered User
    Donor NAWCC Member
    Jul 3, 2016
    961
    Carson City, Nevada
    I suspect your movement and the instructions do not match. One version had electric assist winding where you had to occasionally pre-wind the springs which is what the instructions refer to. On those, that winding key would fit onto arbors on the back plate.
    There are other movements where the electric motor drives the hammer works directly at the proper times with no spring involved. This movement looks like the direct drive rather than the wind assist version.
  3. JoyF
    Jun 4, 2013
    212
    You may be right. Thanks.
  4. JoyF
    Jun 4, 2013
    212
    I looked closer and found the arbors! Clock still doesn't work though.:(
Similar Threads - Seth Thomas Westminster Forum Date
Seth Thomas Electric westminster clock is missing its motor?? Electric Horology Aug 14, 2015
1942 Seth Thomas Westminster Electric Horology Sep 20, 2014
Help needed with Westminster side of Seth Thomas Electric/Mechanical clock Electric Horology Mar 13, 2014
Seth Thomas/Sangamo Westminster Mvmt I-D HELP! Electric Horology May 16, 2009
Seth Thomas Electric Westminster Electric Horology Jul 9, 2007
