Seth Thomas tambour case - what would you do?
Discussion in 'Clock Case Restoration and Repair' started by Schatz70, Jan 16, 2020.
  1. Schatz70
    Schatz70 Registered User
    Oct 5, 2019
    111
    I'm looking for advice from more experienced restorers on what to do. This is a Seth Thomas tambour case for a 124F chiming movement. The back of the hammer mechanism is stamped 4610 which indicates October 1946 and there is a penciled date of 4/22/47 on the bottom of the case, visible in the second picture. The biggest issue is that there is a chunk of wood about half an inch wide missing from the floor. What would you do? I think my best option is to replace the floor. The original floor is about a quarter inch thick. Given that the floor serves as a sound board for the chime rods, what kind of wood is best? Is plywood acceptable?
    The second photo shows the two holes for mounting the chime rods on the right. One of the two bolts was missing but I've found a suitable replacement (the one on the left in the fourth photo). The patina on the replacement bolt doesn't match that of the original, but it's the right length and thread size so I'm gonna use it - I'll put it in the back so it won't show as much.
    Seth Thomas tambour 124 01 15 2020 004.JPG Seth Thomas tambour 124 01 15 2020 001.JPG Seth Thomas tambour 124 01 15 2020 002.JPG Seth Thomas tambour 124 01 15 2020 009.JPG
  2. Schatz70
    Oct 5, 2019
    111
    The glass is missing from the bezel. There are three brass retainers held in by screws, so it looks straightforward to put a replacement in. Should I buy a convex piece of glass or flat?
  3. Schatz70
    Oct 5, 2019
    111
    The finish on the case looks pretty bad - scratches, dents, a splotch of black paint, a couple of splotches of green paint, parts that look very dull. What would you do? Attempt to restore the existing finish, and if so, how? Sand off the finish and start over, and if so what kind of stain would you use and what sort of top coat? I think the wood underneath is pretty nice so this case can be made to look good, but how would you do it? Sorry if I'm asking a question that has been asked many times before.
    Seth Thomas tambour 124 01 15 2020 005.JPG Seth Thomas tambour 124 01 15 2020 006.JPG Seth Thomas tambour 124 01 15 2020 007.JPG Seth Thomas tambour 124 01 15 2020 008.JPG
  4. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    5,956
    349
    You might do some research on this model to find out what was used originally.
    Just looking at your photos:
    Sure you could use plywood. Spruce would have better sound quality but good luck finding a piece 1/4" thick. You might glue up a strip to replace the missing wood. A long glue joint with the grain should be strong enough to hold. The Gong Block (or Boss) might be a problem again though.
    Check to see if a flat piece of glass would give adequate clearance for the minute arbor. If so, your choice, otherwise convex glass should be used.
    The finish is pretty beat up and weathered. You could go as conservative as possible and apply a high maintenance finish/oil on it like Lemon Oil and Bees Wax. Personally, I think I would clean it up as well as I could, getting all of the paint off and re-evaluate it from there. It might clean up nice. There are "scratch hiding" staining-polishes that often give good results to slightly damaged finishes. If you end up stripping what's left of the old finish, I would try to match the color of the original stain as it remains on the bottom, or other "sheltered" surfaces like the inside of the door or even under the applied brass chapter ring. I would go with a Shellac top coat, finishing with a good paste wax.
    Good luck with it,
    Bruce
    Schatz70 likes this.
