Seth Thomas ships clock
Darrmann39
Dec 6, 2020
1,186
390
56
I have this Seth Thomas ships clock I seen l restored. All back together running strong but the strikes aren't aligning with time.
The count wheel and strike wheel interact by another gear. So I'm assuming I should have made a mark on the 2 before disassembling it. So basically I have to take the top plate off and align them right. Any help would be appreciated
The 2nd pic the green dot is the beginning of the 4 hour sequence.
20221029_171400.jpg 20221029_171307.jpg 20221029_171325.jpg 20221029_171316.jpg
5,839
1,030
What exactly do you mean with " the strikes aren't aligning with time"? Is the clock striking the correct sequence but just not in agreement with the position of the hour hand or is something else off?
Darrmann39
Dec 6, 2020
1,186
390
56
So to start dingding is one hour ding is half hour. At one point in the sequence it hits dingding dingding ding dingding dingding. If you understand ship clocks that's not right.
Dingding dingding ding is 2:30/6:30 or 10:30. But the two dingding dingding after is nothing.
5,839
1,030
You need to position the strike wheel correctly. You will have noticed that it has long and short pins. the short pins responsible for the "silent" half hour strike. The best explanation I found is in the book "The modern clock" By Ward L Goodrich. Here is a link. The article you need starts on page 313.
Darrmann39
Dec 6, 2020
1,186
390
56
Thank you. I figured I had to sync the 2 but hard to figure out exactly where
R. Croswell
13,218
3,015
www.greenfieldclockshop.com
These can be a challenge. This may help (see picture). Start by aligning these wheels as shown and tie them together so they don't slip during assembly. Note the alignment is not a perfect tooth over tooth match so, it may take a couple tries to get it right. Align the other parts as shown before assembly. Above all DO NOT bend the little lifting tabs in an attempt to get it right.
Darrmann39
Dec 6, 2020
1,186
390
56
Thank you. After looking at it many times I figured that was the alignment. Great to have confirmation. Still seems damn tricky. But love the diagrams. Thanks
Fitzclan
Jul 20, 2014
775
71
Long Island, New York
Thanks for that RC. Haven’t had the pleasure of tackling one of these yet, but your pictures and info will no doubt save a lot of time and stress when one comes by. Much appreciated.
Darrmann39
Dec 6, 2020
1,186
390
56
Wow that was quite the test of patience. The bitch is you have to take the strike train apart to get that arbor loose that locks these together.
Only about 7 tries and I finally got it. Thanks alot for the diagrams
Darrmann39
Dec 6, 2020
1,186
390
56
Finished. Quite the challenge. Great learning experience. Thanks to R. Croswell. Had to make a new count wheel bar. And the little mount that holds the balance spring stable.
Running strong and striking right
20221102_150232.jpg 20221102_150237.jpg 20221102_150228.jpg 20221102_105317.jpg 20221031_174935.jpg 20221031_153058.jpg 20221029_171400.jpg 20221029_171353.jpg 20221029_171248.jpg 20221027_122626.jpg 20221027_115814.jpg 20221029_171316.jpg
184,077
1,607,746
56,024
dslusf
3,195
Top Bottom
