Seth thomas ship clock with external bell running too fast
eteo66
Mar 31, 2008
263
Hi,
I have the above clock. It is running too fast even though I have set the S-F setting all the way to slow. I have not worked on this type of clock before so can someone point me in the right direction? A book dealing with this clock would also be useful. Thanks!
eskmill
Aug 24, 2000
7,135
32
Most likely the balance spring (hairspring) is either magnetized or has one or more spirals cohereing (sticking together) due to magnetism or oil.
Other causes: balance spring pinned too short; wrong balance spring; regulator pins too close and not allowing balance spring to "breathe."
eteo66
Mar 31, 2008
263
Thanks Ekmill. How shall I go about repairing this? Is there a reference book for this type of movement? Thanks once again.
44,295
1,347
I'm butting in, but first you need to determine which of the problems Les described is causing the problem. Check for magnetism with a compass, then come back with the results. We can start eliminating possibilities then :)
Cactus50
Jan 28, 2001
467
manor, Texas
The usual cause of this condition is a dirty works. Reduced power from the time train produces a low amplitude rotation of the balance wheel - which makes it run faster. The cure is simply to clean the movement and platform, paying close attention to the pivots and pivot holes for wear. Do not start by trying to "adjust" the platform.
eteo66
Mar 31, 2008
263
hi thanks but is there a book i can refer to? I have only worked on pendulum clocks before. I think this is a seth thomas no. 7 movement.
Tony Ambruso
Dec 2, 2005
734
www.azclocks.com
Yes, eteo, there is a book you can refer to for a S.T. no. 7. Steven Conover's "Striking Clock Repair Guide," page 69. You can obtain this book from many places, including the NAWCC gift shop, various horological suppliers (like Merritt's or TimeSavers); or you can visit the author's website Click Here.
eteo66
Mar 31, 2008
263
Hi,
I do have this book but it mainly refers to the striking mechanism rather than the time movement. There is a rough line diagram showing the time movement. What I am looking for is a step by step dismantling guide. Is there one? thanks!
eteo66
Mar 31, 2008
263
Alternatively, is there a similar Seth thomas movement I can purchase and practise on? What number should I get?
Tony Ambruso
Dec 2, 2005
734
www.azclocks.com
eteo66 said:
Hi,
No, I do not believe there is any such manual. General disassembly is covered by some texts, but nothing specific for each type of clock. For example, general disassembly and cleaning is covered in Conover's "Clock Repair Basics."
The chapters in "Striking Clock Repair Guide" cover the most unique aspects of the specific clock. It's striking mechanism is that aspect for this clock. Otherwise, chapters would begin to get painfully redundant.
eteo66
Mar 31, 2008
263
Ok, I'm slowly giving it a go.
First off, how do I remove the second hand?
Do I simply pull it off carefully?
eteo66
Mar 31, 2008
263
Thanks. Is there a similar movement that I can practise on? If so, what number would that be? By the way, how old is the clock? Thanks
R. Croswell
10,648
949
www.greenfieldclockshop.com
As far as the time side goes, you can get valuable practice with almost any movement that has a similar balance wheel escapement. But the information I have is that the Seth Thomas No. 7 ship's bells movement, at least the one in Steve Conover's book, uses a bell strike design that is significantly different from many other popular designs. So It would be best if you could find another No. 7. This is a relatively valuable clock, so I suggest that you consider having someone with experience get this one working for you, and if you want to practice working on clocks, possibly select a simpler and less valuable movement to experiment with.
Bob C.
eteo66
Mar 31, 2008
263
Hi Bob, thanks for your input. As the title says, its the time side I'm looking at rather than the bell strike side. I will at least take the dial off and look at the movement and probably send it in for repair. Thanks a lot!
Topic related ad experiment
160,838
1,395,477
82,860
srhuston
1,099
2,778
