Seth Thomas Regulator No. 2 question
Discussion in 'General Clock Discussions' started by Walt Wilson, Jun 14, 2008.
  1. Walt Wilson
    Walt Wilson Registered User
    Sep 10, 2002
    74
    Engineer/Scientist
    Huntsville, AL
    I have seen or heard somewhere that General Time once released a commerative Regulator No. 2. If this is true, how closely did this mimic the original? I have just brought home what appears to be a pristine example of a Reg. No. 2 but some things about it seem almost too new and fresh. The mvmt is marked with the ST logo and a number. It is the rectangular mvmt rather than the trapezoidal mvmt. The dial is on a fairly thick steel disc and looks almost new but the printing reminds me of a modern print press. Thanks for any info... Walt
  2. owen.or
    owen.or Registered User
    Aug 26, 2000
    1,161
    retired high school teacher
    Near Portland, Oregon
    Walt, Seth Thomas Clock Co. became a division of General Time in in 1931. General Time became a division of Talley Industries in 1970. There is an article in the October, 1988 NAWCC Bulletin edited by Paul Heffner regarding reproduction Seth Thomas No. 2 clocks. It states, "Early in 1976 I accepted an offer from the Seth Thomas Co. for a Seth Thomas No. 2 Regulator. It was to be built as a part of our country's bicentennial celebration and there were to be only 4000 made." The article suggests that the movements in these clocks were made in Germany by Hermle with escape wheel and verge subcontracted to India. The article suggests methods for correcting flaws in the movements of these clocks. It is entirely possible that there were other sources of #2 repros. I know many parts for these clocks are still available. David "owen.or"
  3. inbeat
    inbeat Registered User
    Nov 10, 2000
    1,852
    Portland, Oregon
    It sounds like a Seth Thomas #2 Re-issue.
    The thick dial, movement with the large S-T and a numeral are examples of the reissue....
    An original rectangle #2 movement would have either no markings, or the small Seth Thomas logo in a diamond....
    They made 4000 of these and were supposed to have a label in the bottom indicating what number of the 4000 that particular clock was.
    Solid oak, heavy...plywood backboard when you look at the top and phillips head screws unless someone changed them to fake an old look.
    Still a nice clock.
  4. inbeat
    Nov 10, 2000
    1,852
    Portland, Oregon
    Sorry David,
    We must have been typing a the same time.
  5. eclecticbeat
    eclecticbeat Registered User
    Jul 13, 2007
    302
    39°59'1"N 75°48'60"W
    Hi Walt,
    According to Tran Du Ly - In 1976 there was 4000 factory re-issues produced. 1880's style #2, with weight visible, 12 inch Roman numeral dial in the fancy tri-shaped bottom case. The cases are a very nice copy but reported slightly taller, measuring 36 inches instead of 34.
    There was and still is other sources for #2 reproductions. There are at least two companies making and selling them today but with Arabic numerals on the dial.
    http://www.crescentclock.com/
    http://bradleywoodworks.com/index.html
  6. inbeat
    Nov 10, 2000
    1,852
    Portland, Oregon
    Attached is a picture of a "Re-Issue" movement for a #2....sometime the ST and the numerals are on the upper side of the movement instead of the lower.
    I have had 7 or 8 of these over the years and at one point bought 3 still in their packing boxes that had been stored in someone's closet. They originally came with brochures and a pendulum tiedown made of wood.
  7. Walt Wilson
    Sep 10, 2002
    74
    Engineer/Scientist
    Huntsville, AL
    Thank you all very much. From your answers and pics I can identify the clock as one of the GT (Talley) repros, it being 36 inches from tip to tail, and the mvmt looking nearly identical to the posted one. The dial is Roman which leaves out the contemporary repros, ergo I assume I have one of the 4K originally issued in 1976. I am pleased to have it as I have already an very nice original with trap plates. The price was right at an estate sale, well under 500 clams, and I probably have done no damage to myself. I only wish the paper was in the bottom with the sequence number of the clock.. Thanks again... Walt ... PS my true gem was found also at this same estate sale and I am going to post a question on that clock also... Walt
  8. Steven Thornberry
    Jan 15, 2004
    21,761
    916
    Ne’er do well
    Here and there
    I reopen this to ask a question based on something I saw the other day. It was what appeared to be a reissue No. 2, but the movement, which was like the one shown above, was marked H-T Clock-Makers, Inc, NYC on the front plate. On the back plate, was the dreaded word Korea. I had thought the movements for the reissue were made in Germany, however, they may be marked. Did the Koreans make a knock off of the No. 2, perhaps in competition with the reissue?
  9. curly
    curly Registered User
    May 17, 2001
    74
    retired
    Northern Wisconsin
    Not really an answer to your question, but I have a partial movement in my parts bin that has HT clockmakers New York and what may have said Korea on the backplate has been obscured by an engraving tool. I don't know what kind of case this came out of but I have heard of #2 style cases made in Korea. I have not seen one close up, only pictures and they appear to be vary similiar to the Seth Thomas #2's.
    Curly
  10. inbeat
    Nov 10, 2000
    1,852
    Portland, Oregon
    Seven T.,
    The Reissue #2 mvts were not made in Korea.
    Reproduction cases could have what ever movement they put into them.
    Many people call reproductions Reissues.....
    See the post by Clockpoor on his #5.
  11. salvtrinny
    salvtrinny Registered User
    Sep 13, 2012
    My ST reissue looks exactly like the movement pictured, large S T under that is 61 then, A 414-000, finally 7703, Were these reissues still being made after 1976? And mine has no label. has the thick metal dial, phillips screws hold the dial, and also the stick behind the dial, and also phillip screws mount the cast movement bracket in place
  12. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    152
    deceased
    Hi, Salvtrinny, welcome to the message board.
    I wonder if Hermle continued making these movements for a few years after the official Seth Thomas re-issue? I would guess that they must have made more than just the 4,000 movements required by Seth Thomas, going by Inbeat's findings of loose movements.
  13. inbeat
    Nov 10, 2000
    1,852
    Portland, Oregon
    Harold...they also put this same movement in the factory made Regulator #6 reissues....4000 made supposedly. I have owned three of these over the years and all had the same movements as the reissue #2.
  14. lamarw
    lamarw Registered User
    Jan 5, 2002
    1,643
    Lake Martin, Alabama
    Here is a picture of my Reissue Label;
  15. bruce linde
    bruce linde Technical Admin
    6,319
    683
    oakland, ca.
    inbeat - have you had any issues with the movements in the repros? did you have to mess with them much? thx...
